Chestnut Posted January 28, 2018 Report Share Posted January 28, 2018 Huh i never knew they had different valves on air compressors. My compressor is an Emglo and it came with ball valves. After having this and using my dad's pancake i don't think i could do an oil-less compressor, they are good but the other ones are just better. Quote Link to comment Share on other sites More sharing options...
Mark J Posted January 28, 2018 Author Report Share Posted January 28, 2018 This little DeWalt has a ball valve, too. Yipee, another job I don't have to tackle. Especially nice since the battery back up sump pump broke this morning and I now have to devert my free time to the under-entertaining task of figuring out how to fix or replace it. I emptied the pancake and there was barely a drop. I'm gonna take the "ignore it" tack at least until the summer. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted January 28, 2018 Report Share Posted January 28, 2018 I hope the pipes have a union coupling to make pulling & replacing the pump easier. Quote Link to comment Share on other sites More sharing options...
freedhardwoods Posted January 30, 2018 Report Share Posted January 30, 2018 I don't use my pancake compressor very often. I drain the water when I'm done using it, but not all of the air. On my big compressor, I plumbed in two junk air conditioner condensers (pinholes) out of a semi and a water separator between the compressor and the tank. That removes 99% of the water from the air before it goes in the tank. I added a drain pull valve (pic below) to easily drain the tiny amount of moisture that does get in the 60 gallon tank. I have ball valves to shut off the air to the hoses when I'm not using them. Quote Link to comment Share on other sites More sharing options...
MattSC Posted January 30, 2018 Report Share Posted January 30, 2018 I always empty mine when Im done with it that day. My thought is (probably incorrect) that would help maintain the condition of the seal(s) Quote Link to comment Share on other sites More sharing options...
