Dolmetscher007 Posted February 9, 2018 Report Share Posted February 9, 2018 I am using 3/4" hardwood plywood. I need to create a box that would require a 22-24 inch long mitered joint so as to not show the plys from the wood. There is THIS thing... from Rockler, but it is $350 and not at all worth it for this application. Then there is THIS thing... from Infinity tools. It is a good bit cheaper. Does anyone have any experience with any of these kinds of tools? Project Constraints: The plys cannot show It must be strong enough so that a 300 lb person can sit on the box 22 x 22" cube Can't use visible splines etc. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted February 9, 2018 Report Share Posted February 9, 2018 Lock miter bits will do that in a router table. Just be aware that the set up can be fussy. The bits that have a set up block available is well worth the investment. Featherboards are also a very good idea. Quote Link to comment Share on other sites More sharing options...
curlyoak Posted February 10, 2018 Report Share Posted February 10, 2018 2 hours ago, wdwerker said: Lock miter bits will do that in a router table. Just be aware that the set up can be fussy. The bits that have a set up block available is well worth the investment. Featherboards are also a very good idea. I would add consider spending a little more and get 1/2" shank bits along with a router with decent power. 2hp. or more. Quote Link to comment Share on other sites More sharing options...
Unknown craftsman Posted February 10, 2018 Report Share Posted February 10, 2018 I thinkThat's going to be tough to cut that joint and come out square. Even a box that size with miters would drive me nuts, but then again I'm not really setup for sheet goods so maybe you are. For me I would find it easier to make the box with butt joints and veneer it. Or glue on some laminate you can find it with a wood grain texture. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted February 10, 2018 Report Share Posted February 10, 2018 1/2 shank bits are the only way to cut lock miters on 3/4" plywood. I would use a 2 1/2 hp minimum router. 3 hp preferred. This works but it's not easy or cheap. If you don't have a big router and a decent router table veneer is a safer route. Take a look at Joe Woodworker's website and Veneer Supplies. Paperbacked veneer & contact cement or Heat Lock glue that can be applied then ironed to fix it in place. Quote Link to comment Share on other sites More sharing options...
Marmotjr Posted February 10, 2018 Report Share Posted February 10, 2018 The key to lock miter's, I have found, is proper clamping. Clamp the one side to your bench. I've used I-beams made from LSL in the past, but a work bench that is flat will work. Tape the area where the miter will be, so squeeze out won't stick to the bench top. Apply vertical clamps as you can to pull the miter together, and then tape or clamps at an angle to adjust the miter. Use a square to confirm. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted February 10, 2018 Report Share Posted February 10, 2018 I feel like doing locked miters on all 6 sodes of a cube is going to be extra finicky. If square joins and veneer are not a option, I'd probably lean toward simple miters and a bunch of biscuits. Mmmmmmm.....biscuits. Quote Link to comment Share on other sites More sharing options...
RichardA Posted February 10, 2018 Report Share Posted February 10, 2018 Sausage. Uh huh! Quote Link to comment Share on other sites More sharing options...
Woodenskye Posted February 10, 2018 Report Share Posted February 10, 2018 Domino. 1 Quote Link to comment Share on other sites More sharing options...
wdwerker Posted February 10, 2018 Report Share Posted February 10, 2018 Biscuits, sausage, Dominos.....I've got the beer, who's ordering the pizza ? 2 Quote Link to comment Share on other sites More sharing options...
Coop Posted February 10, 2018 Report Share Posted February 10, 2018 I would cut mitered edges with an internal support such as a 2” square strip glued and screwed to the inside corners. 1 Quote Link to comment Share on other sites More sharing options...
curlyoak Posted February 10, 2018 Report Share Posted February 10, 2018 Why is it imperative to use plywood? Why not use solid? The thickness of veneer is so slight. Solid you can have a better chance of success. Quote Link to comment Share on other sites More sharing options...
shaneymack Posted February 10, 2018 Report Share Posted February 10, 2018 Why don't you use a long spline in the interior of the miter? It meets all your criteria and you don't have to buy anything. 2 Quote Link to comment Share on other sites More sharing options...
Chestnut Posted February 10, 2018 Report Share Posted February 10, 2018 I'd do Shane's method. Is edge banding an option? I cut my own from similar material and with a bit of a rounder over you can usually one see it from one face. Then you can just cut rabbets and not have to deal with it. Quote Link to comment Share on other sites More sharing options...
RichardA Posted February 10, 2018 Report Share Posted February 10, 2018 51 minutes ago, shaneymack said: Why don't you use a long spline in the interior of the miter? It meets all your criteria and you don't have to buy anything. Aw, Shane. I like doing it that way, but go back and reread the title. " A long miter joint without splines". Quote Link to comment Share on other sites More sharing options...
Wimayo Posted February 10, 2018 Report Share Posted February 10, 2018 22 minutes ago, RichardA said: Aw, Shane. I like doing it that way, but go back and reread the title. " A long miter joint without splines". No. He says: "long mitered joint so as to not show the plys". Then he says: "Can't use visible splines etc.". The long spline would not be visible except at the ends. If that is a problem then the spline can be stopped before it gets to the end. A similar option would be a series of close together biscuits that would probably not be as strong, but would be easy to do. Along with this, I think I would be inclined to use epoxy. 1 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted February 10, 2018 Report Share Posted February 10, 2018 If the box is actually a fully closed cube as suggested, those splines would be completly hidden. They would have to stop just short of the corners, though. Quote Link to comment Share on other sites More sharing options...
Isaac Posted February 10, 2018 Report Share Posted February 10, 2018 1 hour ago, RichardA said: Aw, Shane. I like doing it that way, but go back and reread the title. " A long miter joint without splines". Is it no splines, or no visible splines? It would take longer and be trickier, but you produce something similar at the router table that was covered, say 80" of the length of the joint and would still be quite strong and assist in the glue up. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted February 10, 2018 Report Share Posted February 10, 2018 Good Lord this smartphone big brother is getting nosy. 1 1 Quote Link to comment Share on other sites More sharing options...
Immortan D Posted February 10, 2018 Report Share Posted February 10, 2018 You can set a single row of dowels to reinforce the join. But you'll need to buy or make a jig to drill the holes with the required accuracy. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted February 10, 2018 Report Share Posted February 10, 2018 If you go forward with the mitered ply construction I would search for the thickest face veneer possible. That mitered corner is going to be quite fragile. You could build it 5 sided and not worry about the bottom. Quote Link to comment Share on other sites More sharing options...
jplemons Posted February 10, 2018 Report Share Posted February 10, 2018 It will probably be fine without anything additional. Just cut the miters on the table saw and glue it up. Quote Link to comment Share on other sites More sharing options...
Marmotjr Posted February 10, 2018 Report Share Posted February 10, 2018 1 hour ago, jplemons said: It will probably be fine without anything additional. Just cut the miters on the table saw and glue it up. 21 hours ago, Dolmetscher007 said: It must be strong enough so that a 300 lb person can sit on the box 22 x 22" cube Considering I have broken long miters by hand, intentionally and by accident, with very little force, I would hesitate to go this way. Especially not if it's intended to be a chair. Quote Link to comment Share on other sites More sharing options...
Ronn W Posted February 10, 2018 Report Share Posted February 10, 2018 Get the 4 sides together with good fitting miters is hard enough but ( I would use hidden spines) but are you going to miter the top to all 4 sides as well???? Sounds like a nightmare. Here's and Idea.......miter all the corners that you want and then cut a 1/4" x 1/4" dado along each edge of the cube and glue in a 1/4" x 1/4" strip (could be a contrasting wood) along edge. Make strip slightly oversized and then sand flush. These could be mitered at the corners, or not. your choice. This is a little more work but it eliminates the need for 100% perfect miters on all edges. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted February 10, 2018 Report Share Posted February 10, 2018 4 hours ago, C Shaffer said: Good Lord this smartphone big brother is getting nosy. Yep. Sometimes picks up on conversations even when the mic is "off". Quote Link to comment Share on other sites More sharing options...
