Art Posted February 28, 2018 Report Share Posted February 28, 2018 Hello all, I'm making a small cabinet for my daughter and am planning on using some sliding dovetails. I've never done them before, so I'm running some test pieces first so that I can figure it out. I set the depth for the female side, and then nibbled away on the male end to get a decent fit. It's not perfect, but my issue isn't the side to side fit - that is something I can finesse. My problem is the depth. As you can see, there is a sizeable gap at the bottom of the joint. Am I missing something obvious? I figured that as long as I kept the bit at the same height, it would work. Any insight would be appreciated. Thanks, Art Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted February 28, 2018 Report Share Posted February 28, 2018 Routing hand-held, or in a table? First thing that comes to mind if using a router table is that perhaps the mounting plate has a bit of flex. Or maybe the stock was not dead straight? Quote Link to comment Share on other sites More sharing options...
Art Posted February 28, 2018 Author Report Share Posted February 28, 2018 It was on a router table, and as far as I can tell it's fairly rigid. It's a Kreg table. The female end was in poplar that is flat and straight, but the other piece is some scrap pine that may be a bit wavy. Thinking about it later, I figure that I can just adjust the bit a little higher to compensate. I'll run a few more test pieces. Quote Link to comment Share on other sites More sharing options...
treeslayer Posted February 28, 2018 Report Share Posted February 28, 2018 9 minutes ago, Art said: but the other piece is some scrap pine that may be a bit wavy. i always practice with the wood I'm going to use, wavy pine will not get you good results, also be sure on your test pieces that they are not too tight, when you get close use whatever you are going to use (if anything) on the slides, wax, Spipit or whatever and test for fit. good luck and be sure to post some pictures. Quote Link to comment Share on other sites More sharing options...
Midlife Posted March 1, 2018 Report Share Posted March 1, 2018 Going by incras mantra , you " highten to tighten & lower to loosen". Have a look from 4 minutes 20seconds . Quote Link to comment Share on other sites More sharing options...
