collinb Posted March 12, 2018 Report Share Posted March 12, 2018 And this is your wood on a saw blade on resin. Any questions? (Cleaning kits are on sale for $19.99 at Rockler. http://www.rockler.com/router-bit-and-saw-blade-cleaning-kit) (Fortunately I had I left enough slack that this got taken off with the jointer or planer. Had I not ... what a waste. Quote Link to comment Share on other sites More sharing options...
Kurt Triebe Posted March 13, 2018 Report Share Posted March 13, 2018 I used that kit to clean my main TS blade for the first time this weekend, after about a year of hobbyist use. I wasn't getting any burning quite like that, but I was noticing that my cuts weren't nearly as clean as I remember them being before. Kit was super easy to use, I dropped a bunch of router bits into the bath as well and cleaned those up. Worked great, and it's great that you can just capture the liquid and re-use it, rather than having to buy a new bottle of the stuff every few uses. Quote Link to comment Share on other sites More sharing options...
Brendon_t Posted March 13, 2018 Report Share Posted March 13, 2018 Yeah, that's just bad hygiene. Quote Link to comment Share on other sites More sharing options...
Chet Posted March 13, 2018 Report Share Posted March 13, 2018 I use a deep dish pizza pan I picked up at Target for $5, an old tooth brush and Simple Green. Works great. 1 Quote Link to comment Share on other sites More sharing options...
RichardA Posted March 13, 2018 Report Share Posted March 13, 2018 I have a plastic pie carrier with a top. Works perfect. Brass brush, and Simple Green. Quote Link to comment Share on other sites More sharing options...
Ronn W Posted March 13, 2018 Report Share Posted March 13, 2018 Orange Tools Formula 2050 by CMT - from Woodcraft. Works great. Quote Link to comment Share on other sites More sharing options...
Minnesota Steve Posted March 13, 2018 Report Share Posted March 13, 2018 I have a round plastic pan I use to drain oil into when I work on the lawnmower. I've just used washing soda in the past to clean blades... it also helps to clean oil from the drain pan. :-) Quote Link to comment Share on other sites More sharing options...
Popular Post wdwerker Posted March 13, 2018 Popular Post Report Share Posted March 13, 2018 I have an assistant..... 4 2 1 Quote Link to comment Share on other sites More sharing options...
collinb Posted March 14, 2018 Author Report Share Posted March 14, 2018 I read some mixed reports on Simple Green. Works well for some, not well for others -- probably media-dependent. And since the whole solution was on sale I didn't have to spend any time digging up stuff. On 3/13/2018 at 11:11 AM, Kurt Triebe said: I used that kit to clean my main TS blade for the first time this weekend, after about a year of hobbyist use. I wasn't getting any burning quite like that, but I was noticing that my cuts weren't nearly as clean as I remember them being before. Kit was super easy to use, I dropped a bunch of router bits into the bath as well and cleaned those up. Worked great, and it's great that you can just capture the liquid and re-use it, rather than having to buy a new bottle of the stuff every few uses. That burn was actually from a 24T blade, but the Freud was burning, too. I just wanted to show the results of poor hygiene, though I will admit to being just a bit dishonest as a matter of degree. The guy at WoodWerks who recommended it said that he just leaves it filled on the shelf and has had it there for ... several years. Just drop in a blade in the evening and pull it out the next day and brush it off. As long as the lid locks tight the evap is under control. If there is a little, just add water. Quote Link to comment Share on other sites More sharing options...
pkinneb Posted March 14, 2018 Report Share Posted March 14, 2018 Honestly those pics make me think there is more going on there then just resin on the blade. 1 Quote Link to comment Share on other sites More sharing options...
collinb Posted March 15, 2018 Author Report Share Posted March 15, 2018 13 hours ago, pkinneb said: Honestly those pics make me think there is more going on there then just resin on the blade. Hard maple in a 1.5hp saw with a low blade angle.A little dullness wouldn't surprise me but caked-on resins is enough to do this. I know the low angle is safer -- less chance for the blade to pick up and throw a piece. But a high angle doesn't do this so much. The cut is quicker and shorter. (At least that's my perception.) Quote Link to comment Share on other sites More sharing options...
Midlife Posted March 21, 2018 Report Share Posted March 21, 2018 If your cutting wood with a lot of resin try a blade like this, https://www.woodtalkonline.com/forum/87-topics/ Quote Link to comment Share on other sites More sharing options...
