Sign in to follow this
NGrimberg
How to remove small broken tap efficiency & tool supplier
Hello all,
We are going to machining big cnc parts , material Inconel 718 150ksi and a lot of 4-40 UNC thread in; normally with small thread size, we use EDM to remove broken tap, it takes a long time to finish. Do we have any better way to do it? And what tool supplier make the best tap for this material? Thank you.
Share this post
Link to post
Hmm.  Not sure if I've ever seen a question like that answered here but good luck. You may have better luck on a metal working forum.
Share this post
Link to post
Call a local machine shop. I think there is a tool to do this.  I'll ask my son to check with the machine shop at work..
Share this post
Link to post
On ‎5‎/‎9‎/‎2018 at 8:08 AM, NGrimberg said:
Hello all,
We also use EDM for small tap removal, laser might be an option but unless you have a laser in-house it's probably not worth sending outside. If your customer will allow, use form taps in the 718 for 4-40 threads. They are much stronger than regular taps and last a lot longer.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
