crumlett Posted November 17, 2018 Report Share Posted November 17, 2018 Good Morning All, So I have a 5 year old Dewalt DW-735 with the Shelix upgrade. I love the planer but it has developed a very annoying problem. The internal breaker on the planer keeps tripping after about 10 min of use. If turn it off, wait 5 min, reset the breaker, then I can continue using it for another 10-ish min. I've tried the following things: waxed the bed (very fresh coat of wax will allow me to go 20 min vs 10) turned the cutters ensured the blower chute is clear it's on a dedicated 20A circuit. purchased a new breaker for it. (seemed to fix the issue for a month, but now that one keeps tripping.) I always run it on the slow feed setting. Now, I have started using hard woods for various projects, hard maple, pecan, mesquite.... but, it doesn't matter how light of a cut I take or the width of the board. This morning, it tripped on a 3/4" wide strip of hard maple. Does anyone have any ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted November 17, 2018 Report Share Posted November 17, 2018 Brushes /dirty rotor ? Long cord/small gauge cord ? I'm just guessing 1 Quote Link to comment Share on other sites More sharing options...
Mark J Posted November 17, 2018 Report Share Posted November 17, 2018 Maybe the motor is overheating? Quote Link to comment Share on other sites More sharing options...
crumlett Posted November 17, 2018 Author Report Share Posted November 17, 2018 Thanks for the replies. The planer is plugged directly into the outlet and the brushes are good. I agree with y'alls comments that the only thing left really is the motor itself. Quote Link to comment Share on other sites More sharing options...
wdwerker Posted November 17, 2018 Report Share Posted November 17, 2018 If you take the brushes out does the commutator have distinct segments ? Dirty or shorted across the spacers can be an issue. Failing bearings could cause an overheat. Quote Link to comment Share on other sites More sharing options...
crumlett Posted November 18, 2018 Author Report Share Posted November 18, 2018 1 hour ago, wdwerker said: If you take the brushes out does the commutator have distinct segments ? Dirty or shorted across the spacers can be an issue. Failing bearings could cause an overheat. I'll have to check on that in the morning. Thanks! Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted November 18, 2018 Report Share Posted November 18, 2018 At 5 years, how many times has that thermal overload breaker been tripped? They do have a limited number of operation cycles before they become problematic. Might just need a new breaker. If you have access and knowledge to use a volt meter, check your receptacle to be sure you have proper voltage. Also check the other socket of the pair, while the planer is running, to see if the voltage drops. Quote Link to comment Share on other sites More sharing options...
crumlett Posted November 18, 2018 Author Report Share Posted November 18, 2018 1 minute ago, wtnhighlander said: At 5 years, how many times has that thermal overload breaker been tripped? They do have a limited number of operation cycles before they become problematic. Might just need a new breaker. If you have access and knowledge to use a volt meter, check your receptacle to be sure you have proper voltage. Also check the other socket of the pair, while the planer is running, to see if the voltage drops. Hola, I have several dedicated 20A circuits in my shop and the planer trips on all of them. I've also used a DMM to verify the voltage of each circuit. I replaced the breaker already once a couple months ago. The problem got better for a bit then came right back. That made me think that the breaker is not the root cause of the issue. However, a worn breaker is definitely not helping. 1 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted November 18, 2018 Report Share Posted November 18, 2018 Does the planer run with no load, and not trip the breaker? If not, I'd lean toward an electrical issue with the motor. However, if it only trips while cutting, regardless of how lightly, I would suspect a bearing or other mechanical problem in the drive train. One motor drives the cutter, feed rollers, AND the chip ejector fan. Lots of places to bind up. You haven't mentioned odd noises, feed rate changes, or poor chip ejection, all of which would be signs of mechanical failure, so its still mysterious. Just curious, did the segmented cutter help any with the noise that planer makes? 1 Quote Link to comment Share on other sites More sharing options...
Tpt life Posted November 18, 2018 Report Share Posted November 18, 2018 More circuits on the same panel could all be under voltage. Follow each step Ross laid out for you. Quote Link to comment Share on other sites More sharing options...
crumlett Posted November 18, 2018 Author Report Share Posted November 18, 2018 8 hours ago, wtnhighlander said: Does the planer run with no load, and not trip the breaker? If not, I'd lean toward an electrical issue with the motor. However, if it only trips while cutting, regardless of how lightly, I would suspect a bearing or other mechanical problem in the drive train. One motor drives the cutter, feed rollers, AND the chip ejector fan. Lots of places to bind up. You haven't mentioned odd noises, feed rate changes, or poor chip ejection, all of which would be signs of mechanical failure, so its still mysterious. Just curious, did the segmented cutter help any with the noise that planer makes? Correct, it only trips while cutting. I'll pay attention to the bearings when taking it apart today. The segmented cutter did help with the noise, but it is still the loudest thing in the shop by far. 2 Quote Link to comment Share on other sites More sharing options...
crumlett Posted November 19, 2018 Author Report Share Posted November 19, 2018 So, I performed some of the testing prescribed and disassembled the 'easy' components today looked for frayed wires, bad bearings, and just overall something 'Wrong"... -The circuit is supplying 124VAC. This drops briefly to 122VAC when I turn on the planer but never drops below 120VAC even while planing. -All the components attached to bearings seemed able to freely rotate. I tried wiggling each one to see if there's any play and they were all solid. - I removed the brushes and looked at the commutator segments. Nothing seemed out of the ordinary. -before I reassembled it, I took a good 10 min t blow it off with compressed air. I haven't had a chance to use it again extensively, but will keep everyone informed. Thanks again for everyone's assistance. 1 Quote Link to comment Share on other sites More sharing options...
crumlett Posted November 30, 2018 Author Report Share Posted November 30, 2018 Good Evening all, So, I replaced the thermal overload breaker again and started using it. According to the Wixey guage, I'm removing about 0.005" each pass (moving the handle about 1") Hasn't died yet on 13" wide poplar boards. but I'll be selling this one soon since I grabbed a Powermatic 15HH during the sale. Thanks again for all the replies. Quote Link to comment Share on other sites More sharing options...
Chestnut Posted November 30, 2018 Report Share Posted November 30, 2018 jealous i wanted to buy a 15HH during the sale but i must live up to the promise i made myself. Quote Link to comment Share on other sites More sharing options...
crumlett Posted November 30, 2018 Author Report Share Posted November 30, 2018 1 hour ago, Chestnut said: jealous i wanted to buy a 15HH during the sale but i must live up to the promise i made myself. only if ACME will process the dang order. It's still in "received not processed" Quote Link to comment Share on other sites More sharing options...
Coop Posted November 30, 2018 Report Share Posted November 30, 2018 1 hour ago, Chestnut said: jealous i wanted to buy a 15HH during the sale but i must live up to the promise i made myself. Just curious? 21 minutes ago, crumlett said: only if ACME will process the dang order. It's still in "received not processed" Hold their feet to the fire! Quote Link to comment Share on other sites More sharing options...
Chestnut Posted November 30, 2018 Report Share Posted November 30, 2018 10 hours ago, K Cooper said: Just curious? Not to buy anything big until the pickup is paid off. If i can keep expenses low it should be paid off in time for black Friday next year. 2 Quote Link to comment Share on other sites More sharing options...
joe l Posted January 4, 2019 Report Share Posted January 4, 2019 I have had the same issue with my dewalt 735. I have replaced brushes, on off switch, and circuit breaker. Sometimes, it just stops and restarts even with minimal or no load. Anybody got a suggestion? It is on a dedicated 20 amp circuit. Quote Link to comment Share on other sites More sharing options...
Gary Beasley Posted January 4, 2019 Report Share Posted January 4, 2019 Have you checked to see if theres a gfci on the circuit? I hear they dont do heavy loads well. Quote Link to comment Share on other sites More sharing options...
joe l Posted January 4, 2019 Report Share Posted January 4, 2019 No gfci. It is terribly frustrating. At times I'm only taking light (.05) or less of a cut. I also have a problem with chip buildup inside the machine. I have a jet 1150 cfm collector, so I know that's not the problem. Quote Link to comment Share on other sites More sharing options...
Gary Beasley Posted January 5, 2019 Report Share Posted January 5, 2019 Got to wonder if there is a short in the windings. That would result in loss of power and too much juice in the circuit. Quote Link to comment Share on other sites More sharing options...
joe l Posted January 19, 2019 Report Share Posted January 19, 2019 I had the same issue. Discovered the wires to the new circuit breaker were burned at the spade terminal. Couldn't see them without totally removing breaker. Replace said wire and terminals, seems to be ok for now after running 25 or 30 Ft. Of oak. Time will tell. Quote Link to comment Share on other sites More sharing options...
MikeF Posted March 2, 2019 Report Share Posted March 2, 2019 I have a problem similar with my 735 + SHELIX recently. It's worked fine for a year, but the internal breaker has gotten temperamental. I put a Kill-o-watt on the plug and it trips under 18-ish amps. I don't know the baseline if the machine is pulling more juice than normal or if the breaker isn't working right. This is just doing less than 1/4 turn on the wheel. I tried turning the cutters and that seems to help reduce the amps, but still can't push it much. I'm guessing a fresh breaker is my next step. Quote Link to comment Share on other sites More sharing options...
RichardA Posted March 2, 2019 Report Share Posted March 2, 2019 On 1/4/2019 at 4:01 PM, joe l said: No gfci. It is terribly frustrating. At times I'm only taking light (.05) or less of a cut. I also have a problem with chip buildup inside the machine. I have a jet 1150 cfm collector, so I know that's not the problem. How old is the unit? The plastic in the upper chamber takes a serious beating from the chips and leakage starts, and chips fill the upper chamber. Replace all the plastic in the upper chamber, that will solve the chip build up for several years. For the stoppage I have no solution, I haven't had that problem. Quote Link to comment Share on other sites More sharing options...
Boone Posted December 21, 2021 Report Share Posted December 21, 2021 This breaker solved my problem. RKURCK 125-250V AC 50V DC Push Button Circuit Breaker 25Amp Thermal Overload Protector L1 Series Manual Reset Thermal Circuit Breaker 25A 1 Quote Link to comment Share on other sites More sharing options...
