Cuting joints
Thinking of building a spice cabinet was going to try making my own box or dovetail joint for first time to joint the 4 sides of the cabinet.  How does everyone cut their joints and should I invest in a decent hand saw to cut the joint? I’m more of a power tool user but I’m not aposed  to hand tools.
15 minutes ago, wtnhighlander said:
I usually prefer to cut joints on the table saw, but box joints are the one case where the router table does a cleaner job, IMO. The jig is the same design, but needs to be sturdy to resist twisting as the router bites in. A spiral cut bit might help that, but I haven't tried one.
I was thinking of doing it on router because I don’t want to purchase a dado stack right now kinda broke. So was going to do a router based jig.
Whichever way to choose to go, I strongly recommend milling some practice stock to try the joint a few times before trying it on your project. There is a learning curve as you have to defend against blowout and make tiny adjustments to fit it correctly. Whether dovetails or box joints, you'll usually want to cut them slightly proud so you can sand or handplane them flush.
Good luck, please report back with what you end up doing, how it went for you.
I haven't tried the router for box joints, but what you say makes sense. I've yet to see a dado stack that leave a perfectly flat bottom.
Very important point. Box joints need to be very precise in order to get a gapless joint that you can actually get together in glue up. There are many box joint jigs out there, some being extremely complex. I prefer simplicity, hence my recommendation of William Ng's jig.
Regardless of hand tools or power, the first thing to do is dress the lumber. If it is not dressed right it may impede your ability to make everything fit.. Make the wood flat and even in thickness. Then the pieces must be square and opposing pieces must be exactly the same before you begin to make the joint...
  • Who's Online   2 Members, 0 Anonymous, 59 Guests (See full list)
    31.2k
    422k
    23,773
    rojmwq4e
    rojmwq4e
