John Kresich Posted June 17, 2019 Report Share Posted June 17, 2019 My conveyor belt is working intermittently and mostly not working at all. Sometimes it will start up and then stop after 5 seconds. I read the manual and adjusted the conveyor belt tensioners and that’s not it. Also tightened the sleeve (2 Allen wrench adjustments) between the conveyor motor and the conveyor drive and that’s not it either. In fact, when I loosen the sleeve altogether, and turn the conveyor belt motor on, I can see the motor stop even with zero tension on the conveyor sleeve. Can someone help me with a solution. I miss my drum sander. Quote Link to comment Share on other sites More sharing options...
RichardA Posted June 17, 2019 Report Share Posted June 17, 2019 If I were you, I'd call Jet. As I recall, they have good customer service as well as a good warranty. Quote Link to comment Share on other sites More sharing options...
Gary Beasley Posted June 18, 2019 Report Share Posted June 18, 2019 Sounds like damaged reduction gears or a loose setscrew on the conveyor motor. Quote Link to comment Share on other sites More sharing options...
