ben_r_ Posted July 9, 2019 Report Share Posted July 9, 2019 LINK These actually look like a pretty solid panel clamp and a good idea if they work as advertised. But man, at $110 each if you buy 4, they are very pricey! What are your thoughts? Anyone planning on ordering a set? Link to comment Share on other sites More sharing options...
pkinneb Posted July 9, 2019 Report Share Posted July 9, 2019 To steep for my blood but if you do a lot of panel glue ups might be worth it. My only concern would be will the glue play nice with the finish on those bars? Link to comment Share on other sites More sharing options...
ben_r_ Posted July 9, 2019 Author Report Share Posted July 9, 2019 5 hours ago, pkinneb said: To steep for my blood but if you do a lot of panel glue ups might be worth it. My only concern would be will the glue play nice with the finish on those bars? Totally valid question! And for the price they are charging, they really should have ALL those types of issues worked out. From their description the bars and clamp faces are powder coated steel. Anyone know how powder coating does with dried glue? Is it a pain to get the glue off of? Link to comment Share on other sites More sharing options...
Minnesota Steve Posted July 10, 2019 Report Share Posted July 10, 2019 I thought the Damstom clamps were expensive at half that price. :-) Link to comment Share on other sites More sharing options...
Tom King Posted July 10, 2019 Report Share Posted July 10, 2019 Looks like if you needed to squeeze all the glue out of a joint, these would be good for the job. 1 Link to comment Share on other sites More sharing options...
Chestnut Posted July 10, 2019 Report Share Posted July 10, 2019 Don't get what any of these offer over alternating parallel clamps. I also thought parallel clamps were a bit on the spendy side.... as i use these more often than anything else. https://www.menards.com/main/tools/hand-tools/clamps-vises/masterforce-reg-12-f-clamp/3060467/p-1444439537442-c-9135.htm?tid=8287304672883482236&ipos=2 Link to comment Share on other sites More sharing options...
Popular Post Chet Posted July 10, 2019 Popular Post Report Share Posted July 10, 2019 I may be missing something but with proper milling of your edges you shouldn't really need something like this. I did a table top that was just shy of 6 feet long and 38 inches wide and I only used 5 clamps and at that hardly any pressure. I did use a few of the smallest dominos, the ones about the size of chiclets, for alignment but that was it. 3 Link to comment Share on other sites More sharing options...
Immortan D Posted July 10, 2019 Report Share Posted July 10, 2019 1 hour ago, Chet said: I may be missing something but with proper milling of your edges you shouldn't really need something like this. I did a table top that was just shy of 6 feet long and 38 inches wide and I only used 5 clamps and at that hardly any pressure. I did use a few of the smallest dominos, the ones about the size of chiclets, for alignment but that was it. I was wondering about that too. If your edges are not properly milled, chances are your heights will be different, resulting in some kind of random alignment with these 4 way clamps. Link to comment Share on other sites More sharing options...
wtnhighlander Posted July 10, 2019 Report Share Posted July 10, 2019 It looks like the scissor design of the clamping mechanism applies pressure top and bottom as well as side to side, so boards are forced into alignment. If you aren't using dominoes, that is. Link to comment Share on other sites More sharing options...
Chestnut Posted July 11, 2019 Report Share Posted July 11, 2019 12 hours ago, wtnhighlander said: It looks like the scissor design of the clamping mechanism applies pressure top and bottom as well as side to side, so boards are forced into alignment. If you aren't using dominoes, that is. For how much these cost a domino is probably cheaper..... 1 Link to comment Share on other sites More sharing options...
pkinneb Posted July 11, 2019 Report Share Posted July 11, 2019 10 hours ago, Chestnut said: For how much these cost a domino is probably cheaper..... Well you don't see that written very often 1 1 Link to comment Share on other sites More sharing options...
ben_r_ Posted July 18, 2019 Author Report Share Posted July 18, 2019 Cool! And if those weren't expensive enough already, you can now add 50" Extension Rails for an additional $60 PER clamp! Link to comment Share on other sites More sharing options...
ben_r_ Posted January 22, 2020 Author Report Share Posted January 22, 2020 Looks like these didn't end up being all they were marketed to be: LINK Link to comment Share on other sites More sharing options...
