treesner Posted August 6, 2019 Report Share Posted August 6, 2019 You guys know where I could get the hardware to do a flush mount towel rack like this? Or another diy solution? https://www.amazon.com/dp/B06XXHS9NN/ref=cm_sw_r_cp_api_i_rrpsDb60GG4W0 Quote Link to comment Share on other sites More sharing options...
JohnG Posted August 6, 2019 Report Share Posted August 6, 2019 Ace hardware and similar should carry those bolts with machine screw on one side and sheet metal thread on the other. I forget their proper name, but we always carried them at the ace dealer I worked at. Then you can buy the drywall anchors and threaded inserts and you’re set. Edit: They are called hanger bolts. 1 Quote Link to comment Share on other sites More sharing options...
treesner Posted August 6, 2019 Author Report Share Posted August 6, 2019 13 minutes ago, JohnG said: Ace hardware and similar should carry those bolts with machine screw on one side and sheet metal thread on the other. I forget their proper name, but we always carried them at the ace dealer I worked at. Then you can buy the drywall anchors and threaded inserts and you’re set. Edit: They are called hanger bolts. And the sheet metal screw goes into the drywall anchor and the machine goes into the hook with the threaded insert? Quote Link to comment Share on other sites More sharing options...
JohnG Posted August 6, 2019 Report Share Posted August 6, 2019 You got it! At least that’s how they do it in the link you posted. Quote Link to comment Share on other sites More sharing options...
Immortan D Posted August 6, 2019 Report Share Posted August 6, 2019 Hanger bolts: https://www.amazon.com/Coarse-Thread-Hanger-Carbon-Plated/dp/B00Z3XM8C2/ref=sr_1_1?keywords=hanger+bolt&qid=1565098690&s=gateway&sr=8-1 E-Z Lok flanged threaded inserts: https://www.amazon.com/Z-Threaded-Hex-Flanged-Internal-Threads/dp/B002KT43MU?ref_=bl_dp_s_web_3446128011 Quote Link to comment Share on other sites More sharing options...
