sjm1580 Posted August 18, 2019 Report Share Posted August 18, 2019 I am in the middle of veneering a pair of speaker cabinets that I built. They are 40" tall with rounded sides that meet the square front baffle and rear wall at non 90 degree angles. I am planning on trimming the veneer with a flush cutting high tooth count saw. Question, is there a better method? Thanks! Steve Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted August 18, 2019 Report Share Posted August 18, 2019 A rasp or sanding block might offer better control, once the veneer is trimmed fairly close. Quote Link to comment Share on other sites More sharing options...
sjm1580 Posted August 18, 2019 Author Report Share Posted August 18, 2019 That is my plan, to finish it off with a sanding block. Thank you. Quote Link to comment Share on other sites More sharing options...
Ronn W Posted August 18, 2019 Report Share Posted August 18, 2019 If you can lay it flat I would use a veneer saw - less chance of splitting the veneer. Then sandpaper on a hard, straight sanding block Quote Link to comment Share on other sites More sharing options...
