Curtis Posted October 25, 2019 Report Share Posted October 25, 2019 How do cabinet makers attach a decorative frame/panel end panel to the plywood carcass? Mine is a traditional shaker tongue/groove frame/panel door like build (poplar stiles and rails) with 1/4 birch ply as the panel. If I glue it, is there enough wood movement that it would start to break apart the top veneer of the plywood? Should I just "hang it" on the carcass, or nail? I have attach sketch up image. Yellow is plywood. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted October 25, 2019 Report Share Posted October 25, 2019 Well usually glue it with a few nail in the corners or just clamps. We will usually harg it off the front about 3 2nd just to make sure the face frame is tight to the side and clamped. Usually not much movement to be concerned about. Same as my bar.... 2 Quote Link to comment Share on other sites More sharing options...
curlyoak Posted October 25, 2019 Report Share Posted October 25, 2019 Additional plywood not needed. I dado the bulkheads. Screw and glue. Fill the hole with a flat grain plug.You can see more details at https://www.woodtalkonline.com/topic/30450-walnut-office-furniture/ For me I think it would be more work to build around an existing cabinet if that is your situation. But if your level of experience is low it might be a good idea. 1 Quote Link to comment Share on other sites More sharing options...
BillyJack Posted October 25, 2019 Report Share Posted October 25, 2019 It's actually easier because you need only apply. This is easy on an enclosed cabinet. We're your are open some don't like the gaps from the inner panel.. Quote Link to comment Share on other sites More sharing options...
Wimayo Posted October 26, 2019 Report Share Posted October 26, 2019 I think I would just use a few screws through the plywood into the back side of the decorative frame. Expansion/contraction should not be a problem. Quote Link to comment Share on other sites More sharing options...
