Popular Post Dave H Posted April 6, 2020 Popular Post Report Share Posted April 6, 2020 I play pool or, did until all this Corona virus started. I played about three times a week played league one night a week and, played in a couple tournaments, you need a pocket full of quarters to feed the tables. A friend gave me this quarter dispenser ( a plastic cylinder with a spring inside it) It was exactly like this one it fell off a table and broke the catch lip off the top. I saved the spring and, being bored I decided to make one on my lathe so I turned a 1 1/4" cylinder now I needed a 1" all the way through well centered because there was only 1/8" of meat on the edges and needed to be a smooth shaft so the quarter didn't hang up all I have is a drill press I wanted to drill halfway from one end and halfway through the other end. After much cussing and many test runs on scrap wood I came on the solution. I drilled a 1" hole halfway through some scrap 3/4 ply than drilled a small hole the thickness of a 8d nail I drilled the same hole in a square blank of wood the drilled hole worked for alignment on my lathe. I turned a 1" dowel to fit in the 1" hole in the 3/4 ply I cut a 8d nail so it went through the ply and would stick through a sliced piece of the 1" dowel that sat proud of the ply about 1/2", I put the nail in my hand drill and spun it against my grinder making a sharp point in the end now I have a piece of 3/4 ply with a dowel sticking out 1/2" and, a sharpened nail centered through all this. I put my 1" forstner bit in my drill press lowered and locked the quill till it was just slightly above the sharpened nail I moved the plywood around until the sharpened nail and the point of the bit lined up and clamped the ply down to the table. My 1 1/4" cylinder has the center holes already established so I set one end on the sharpened nail bring the forstner bit into the other center hole drill through halfway then I flip the cylinder around and set it over the 1" dowel then drill through the other half and you get as smooth a shaft as you can get with a forstner bit. Anyway I could of bought another dispenser for less than $10.00 but this kept me busy for almost 2 days most of this was coming up with this drill press trick the turning and glue up I would have been done by lunch if I already had the drilling jig figured out. 3 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted April 6, 2020 Report Share Posted April 6, 2020 Nice solution! I enjoy hearing how other folks solve problems with what they have on hand. Always a new trick to learn. 2 Quote Link to comment Share on other sites More sharing options...
Coop Posted April 7, 2020 Report Share Posted April 7, 2020 Just think of the quarters you saved those two days! 1 Quote Link to comment Share on other sites More sharing options...
