houstonwoodworker Posted April 12, 2020 Report Share Posted April 12, 2020 Hey everyone! Please see attached picture. I’m designing a cabinet and the panels will be on inside of legs. I can’t find proper door hardware that will allow the doors to swing out past the doors. Hard to explain so see the pics. Thanks for help!!! Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted April 12, 2020 Report Share Posted April 12, 2020 Euro-style cup hinges give a bit of clearance for such designs, but maybe not enough. Some dimensions might help with the advice. Quote Link to comment Share on other sites More sharing options...
pkinneb Posted April 12, 2020 Report Share Posted April 12, 2020 I agree with @wtnhighlander. If they're recessed much more than say an 1" or so might be hard to find. Quote Link to comment Share on other sites More sharing options...
houstonwoodworker Posted April 12, 2020 Author Report Share Posted April 12, 2020 Yes thx! I haven’t designed it exactly yet but it would be 3/4” max, probably closer to half an inch. Quote Link to comment Share on other sites More sharing options...
Chestnut Posted April 13, 2020 Report Share Posted April 13, 2020 You'll need to go through the Blum concealed hinge brochure and find the right hinge and mounting plate for your situation. currently I'm getting a 404 error but it's located here https://www.blum.com/us/en/products/hingesystems/clip-top-blumotion/downloads-videos/ By the looks of it you'll need the Blum 71t6550 and the 70.6103 with a 9mm mounting plate. you can have about a 15.5 mm recess with a 25mm thick door. A thiner door may allow more recess but tests would need to be completed. You'll only be able to open to door to about 130 degrees. I order Blum from these guys a lot they have good prices and ship fast. https://www.woodworkerexpress.com/blum-170deg-clip-top-hinge-full-overlay-screw-on.html 1 Quote Link to comment Share on other sites More sharing options...
pkinneb Posted April 13, 2020 Report Share Posted April 13, 2020 Looks like Drew's got you set up with his post above. wwhardware.com is another online source. I have used those on my shop cabinets so if some pics would be helpful let me know. Quote Link to comment Share on other sites More sharing options...
houstonwoodworker Posted April 13, 2020 Author Report Share Posted April 13, 2020 Thx so much. Have figured out that I need one that has the clearance and is inset as any overlap won’t work. I’ll check out the sites. Quote Link to comment Share on other sites More sharing options...
