Norton Posted May 12, 2020 Report Share Posted May 12, 2020 Greetings to all woodworkers. I'm attempting to edge band veneered plywood with 1/2" thick mitered strips that surround an end table top. Seems the proper way is to leave both edges slightly proud so they can be flushed after glue up. Flushing the overhanging edges is my dilemma compounding the feat with miters. Any and all suggestions would be more than appreciated. Please stay safe and find some joy in these trying times.Thanks Richard Quote Link to comment Share on other sites More sharing options...
treeslayer Posted May 12, 2020 Report Share Posted May 12, 2020 I’ve done it with a 1/4” flush trim bit in the router, finish the corners with sandpaper and a block of wood to prevent tear out, block plane would work if you’re careful and finish with sandpaper, I’m sure others will chime in who have done this more that I have, good luck and welcome Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted May 12, 2020 Report Share Posted May 12, 2020 For router trimming, I suggest clamping a board or two against the non-work side of the ply to give your router a wider platform. Even with a bearing-guided bit, wobbling the router along the narrow edge is likely to ruin your day. 1 Quote Link to comment Share on other sites More sharing options...
Chip Sawdust Posted May 12, 2020 Report Share Posted May 12, 2020 FWW just published an article on waterfall edge banding with miters, you may be able to get some good pointers out of that article. Quote Link to comment Share on other sites More sharing options...
Ronn W Posted May 14, 2020 Report Share Posted May 14, 2020 I would use a block plane to get really close and then smooth with sand paper. If you skew the balde in the plane so that the edge that is over the veneer cannot cut, you can reduce the risk of snagging the veneer. Take very thin shavings as you get closer to flush. 1 Quote Link to comment Share on other sites More sharing options...
