HarveyM Posted September 7, 2020 Report Share Posted September 7, 2020 I put OSB on platon membrane (the dimpled plastic used around basement foundations) with tapcons in our basement. If you used oak or maple faced plywood you'd have a quick, decent looking floor that's easier on your feet or dropped tools. Quote Link to comment Share on other sites More sharing options...
Jim DaddyO Posted September 8, 2020 Report Share Posted September 8, 2020 You can get a product called Dri core that is meant for basements. It has a plastic on the bottom and particle board on top. The plastic keeps the wood from direct contact with the floor and has channels that let moisture move to drains, etc. It is T&G I think so it locks together. A couple of coats of varithane or paint and done. 1 Quote Link to comment Share on other sites More sharing options...
Mark J Posted September 8, 2020 Report Share Posted September 8, 2020 @Jim DaddyO, will this stuff support the weight of machinery? Quote Link to comment Share on other sites More sharing options...
HarveyM Posted September 8, 2020 Report Share Posted September 8, 2020 I thought the expense of Dri core & having a moisture/water barrier (fewer seams) were advantages for Platon. (I've had basement flooding in the past, so that's a big issue for me) There's instructions on their website on using Platon as an underlayment. They say "Average floor loading of 80 lb/sq.ft at temperature less than 102° F 39° C , less than 1/8” 3mm deflection" so a 4'x8' plywood sheet spreading the weight would support 2,560 lbs by my back of envelope math. Quote Link to comment Share on other sites More sharing options...
drzaius Posted September 8, 2020 Report Share Posted September 8, 2020 1 hour ago, HarveyM said: I thought the expense of Dri core & having a moisture/water barrier (fewer seams) were advantages for Platon. (I've had basement flooding in the past, so that's a big issue for me) There's instructions on their website on using Platon as an underlayment. They say "Average floor loading of 80 lb/sq.ft at temperature less than 102° F 39° C , less than 1/8” 3mm deflection" so a 4'x8' plywood sheet spreading the weight would support 2,560 lbs by my back of envelope math. I would be concerned with point loads under heavy machinery at the plywood seams. Quote Link to comment Share on other sites More sharing options...
HarveyM Posted September 8, 2020 Report Share Posted September 8, 2020 It is intended to be a home shop, not a industrial space. As a finished plywood floor the seams would be visible. Option B would be using it as subfloor and 'protect' it with a flooring layer. Quote Link to comment Share on other sites More sharing options...
Jim DaddyO Posted September 8, 2020 Report Share Posted September 8, 2020 4 hours ago, Mark J said: @Jim DaddyO, will this stuff support the weight of machinery? I guess @HarveyM more or less answered the question. If his numbers are quoted from the manufacturer and it looks like it should. Most hobby weight machinery has no more point load than the 4 little feet under a large refrigerator. If in doubt you could put some wider pads under the machinery to spread the load a bit. It doesn't look like there are any large spans under the dri-core anyway. It would also be a good platform for future finished floor on top of it too. Spread the expense over time if you choose to go that route. Personally, I'd just paint it. I have painted plywood floors on my present shop and I love them. 1 Quote Link to comment Share on other sites More sharing options...
Tpt life Posted September 8, 2020 Report Share Posted September 8, 2020 I’d have to level my basement or garage floors a LOT to make those work. Quote Link to comment Share on other sites More sharing options...
drzaius Posted September 8, 2020 Report Share Posted September 8, 2020 5 hours ago, HarveyM said: It is intended to be a home shop, not a industrial space. As a finished plywood floor the seams would be visible. Option B would be using it as subfloor and 'protect' it with a flooring layer. It's not the visibility of the seams I was addressing, but rather the compression of the Platon as a heavy wheel passes over a seam. Not a concern if there are no really heavy machines. 1 Quote Link to comment Share on other sites More sharing options...
Mark J Posted September 9, 2020 Report Share Posted September 9, 2020 I'm reading through the last several post again, and it appears we're talking about two different products, Platon under a 3/4" plywood layer and Dri Core. I'm not familiar with either so I've no reason to think either is a bad choice. But for me I want all my equipment on wheels and to roll freely when needed. Now I have no idea off hand what the point loading is under the foot of, say my industrial table saw, but a 1/8" deflection is actually going to significantly impede rolling, at least initially. On the other hand HarveyM has done it, so what's the real world experience with rolling big equipment on the Platon? Quote Link to comment Share on other sites More sharing options...
