BryanFaz Posted December 23, 2020 Author Report Share Posted December 23, 2020 No clue about this motor. Since I confirmed power was leaving the power switch, I checked the continuity on the motor through the brush holes. Assuming it can be checked in that manner, the motor had continuity. Yet, it will not power on. Won’t even hum, not a sound. What is the darned problem. Quote Link to comment Share on other sites More sharing options...
Tpt life Posted December 23, 2020 Report Share Posted December 23, 2020 There are two windings that can fail inside a motor, the armature and the stator. Through the brush holes just puts you on the commutator. It would be good to verify the stator windings if you think the motor is faulty. 2 Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted December 23, 2020 Report Share Posted December 23, 2020 That type of motor is called a "universal" motor. See the link for an overview of its function. @Tpt lifeis absolutely correct. The good news is that the stator winding SHOULD have an external wiring connection, meaning that connection could be the problem, rather the the internals of the motor. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post BryanFaz Posted December 24, 2020 Author Popular Post Report Share Posted December 24, 2020 MYSTERY SOLVED! I believe we located the issue. The picture at the bottom displays the culprit. There was a connector on the housing where the brushes are located. The connector broke. We tried to solder it back, after breaking the plastic housing, unsuccessfully. Trying to track down this part. I sure hope this is the problem...it makes sense. 3 Quote Link to comment Share on other sites More sharing options...
Coop Posted December 24, 2020 Report Share Posted December 24, 2020 Hopefully this is the problem and that you can get the part and also helps others in the future.,let us know. Good detective work! Quote Link to comment Share on other sites More sharing options...
BryanFaz Posted December 24, 2020 Author Report Share Posted December 24, 2020 Thanks to all you guys/gals for your input and assistance. I found the part at repairtoolparts.com for $7.00. It’s part # 5140011-86, brush holder. I’ll let you know when it comes in. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post BryanFaz Posted January 12, 2021 Author Popular Post Report Share Posted January 12, 2021 Hey guys!! I have very good news...I replaced the brush holder and the planer is working like a champ!! I really appreciate everyone’s help and advice. I’ll be back soon!!! 2 1 Quote Link to comment Share on other sites More sharing options...
Mattbair Posted February 12, 2022 Report Share Posted February 12, 2022 I have the Dewalt dw735 type 1 and I have got power to the motor but it will not run anyone know what would be going on Quote Link to comment Share on other sites More sharing options...
Coop Posted February 12, 2022 Report Share Posted February 12, 2022 Did it just stop working? Had you taken the cover off for any reason prior to it not working? Did you check the brushes? Quote Link to comment Share on other sites More sharing options...
treeslayer Posted February 12, 2022 Report Share Posted February 12, 2022 3 hours ago, Mattbair said: I have the Dewalt dw735 type 1 and I have got power to the motor but it will not run anyone know what would be going on I assume that you checked the fuse on the front, I had a problem like that once and it was one of the brushes was stuck not touching the arbor, you can access them from a small door in the back Quote Link to comment Share on other sites More sharing options...
treeslayer Posted February 12, 2022 Report Share Posted February 12, 2022 And what @Coopsaid if you remove the cover over the knives there is a switch there too Quote Link to comment Share on other sites More sharing options...
Coop Posted February 13, 2022 Report Share Posted February 13, 2022 And the obvious black reset button in the front, next to the power switch. Quote Link to comment Share on other sites More sharing options...
Tannerr52 Posted October 10, 2022 Report Share Posted October 10, 2022 I just found this post and you saved me! My holder was fine, but the connection to the holder was broken. New $.03 spade connector and good as new!!! Thank you! 1 1 Quote Link to comment Share on other sites More sharing options...
