jmb Posted November 26, 2021 Report Share Posted November 26, 2021 rocker seems to have a pretty good deal on one of these with a mobile stand. I have read reviews on amazon and they are kind of mixed. I have 240 volt as well as 120. should I be looking at something different? I am a beginning woodworker. cost is a factor of course but a couple of hundred bucks is not going to break the bank. Thanks in advance for all replies. JB Quote Link to comment Share on other sites More sharing options...
Coop Posted November 26, 2021 Report Share Posted November 26, 2021 I think if you do a search on here for the 735, you’ll find it to be very popular amongst us hobbyists. I bought my first one 9 years ago and replaced it with the same, 3 months ago. Pull the trigger, you’ll be glad you did. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted November 26, 2021 Report Share Posted November 26, 2021 To step up to a floor-standing planer will pretty much double the price, although you may get 15" of width, vs. 13" for the Dewalt. The only bad thing I have to say about the DW735 is that it is LOUD. My shop is an insulated building, separated from the house by about 10' at the nearest corner, and the noise still drives my wife crazy, inside the house. If you are able to obtain a 240v unit, it should be less likely to overheat during long milling sessions, as it will draw less current for the same horsepower. Quote Link to comment Share on other sites More sharing options...
Ronn W Posted November 26, 2021 Report Share Posted November 26, 2021 It's a good unit for a home wood working shop. Blades are easy to change and each blade has 2 cutting edges, one for now and one when its time to change. Keep the rollers clean with menral spirits. When its comes to Dust collection, remember that it has its own powerful fan that expells the chips. Enjoy. Quote Link to comment Share on other sites More sharing options...
Askland09 Posted November 26, 2021 Report Share Posted November 26, 2021 I've had one for about a year now and I only have 2 complaints with the unit. 1. It is extremely loud which is easily remedied with a set of ear buds and your favorite tunes/podcast/etc. 2. I've had problems with the outfeed table coming out of flush with the unit. More of an annoyance than a problem. Other than those two issues its been a great addition to my shop. Quote Link to comment Share on other sites More sharing options...
Coop Posted November 26, 2021 Report Share Posted November 26, 2021 On 11/26/2021 at 2:14 PM, Askland09 said: 2. I've had problems with the outfeed table coming out of flush with the unit. More of an annoyance than a problem Raise your unit up off of the table to get a straight edge onto the table and outfeed table (not on the in feed table). Adjust your out feed table to where it is flush with the main table then tip the outside edge of your out feed up just a tad and secure it. Then do the same with the in feed but leave it flush with the main table and secure it. 2 Quote Link to comment Share on other sites More sharing options...
G Ragatz Posted November 29, 2021 Report Share Posted November 29, 2021 FWIW, the current issue of Wood magazine has a comparison of 15 benchtop planers, including 7 more expensive than the 735X. The 735X was their "Top Tool." Quote Link to comment Share on other sites More sharing options...
Askland09 Posted November 29, 2021 Report Share Posted November 29, 2021 On 11/26/2021 at 2:36 PM, Coop said: Raise your unit up off of the table to get a straight edge onto the table and outfeed table (not on the in feed table). Adjust your out feed table to where it is flush with the main table then tip the outside edge of your out feed up just a tad and secure it. Then do the same with the in feed but leave it flush with the main table and secure it. The issue is that the adjustment has slipped 2 times and come out of where I had originally tightened it down. Its an easy fix, just annoying. Quote Link to comment Share on other sites More sharing options...
fcschoenthal Posted November 29, 2021 Report Share Posted November 29, 2021 On 11/26/2021 at 2:36 PM, Coop said: Raise your unit up off of the table to get a straight edge onto the table and outfeed table (not on the in feed table). Adjust your out feed table to where it is flush with the main table then tip the outside edge of your out feed up just a tad and secure it. Then do the same with the in feed but leave it flush with the main table and secure it. On 11/29/2021 at 8:05 AM, Askland09 said: The issue is that the adjustment has slipped 2 times and come out of where I had originally tightened it down. Its an easy fix, just annoying. I have used a 3/4"x13"x6' piece of melamine as a table platform for years and it has almost eliminated any snipe without messing with the tables. I'm probably going to take them off soon to make it easier to tuck away. Check around before you pull the trigger for $650, I waited a couple of months before I found mine through Craigslist about 3 years ago. The guy was moving and couldn't take it with him. Got the 735X with stand for $400. He had only used it once. Quote Link to comment Share on other sites More sharing options...
