TomInNC Posted April 26, 2022 Report Share Posted April 26, 2022 I use the Incra miter express for most cross cut operations. For small and medium pieces, the sled works very well. Large pieces that extend well beyond the width of the sled, however, want to tip down off the sled. This makes operations like cutting tenons on large legs tricky because of how much downward pressure you need to use while simultaneously pushing the sled through the cut. Has anyone successfully modified the miter express to address this issue? I use the sled in the left miter slot, and I also have a router table extension on the left side with another miter slot. I am thinking that if there is someway to attach a panel that is the exact height of the one on the sled, I wouldn't have the tipping issue. The sled base is 1/2 MDF plus whatever the red coating adds in thickness, so 1/2 MDF wouldn't match the thickness exactly. I know I could just build some monstrous cross-cut sled that could span the whole space, but (1) I don't really have room to store one and (2) this would probably require me to take out a second mortgage given the current price of plywood. Quote Link to comment Share on other sites More sharing options...
Chestnut Posted April 26, 2022 Report Share Posted April 26, 2022 By large you mean length perpendicular to the saw blade? I think the benefit to the miter express is being able to remove the miter gauge from the sled. For long items reference the table saw surface might offer more stability than referencing the sled surface. Another option that could work well is to use your planer and just make a spacer the same thickness of the red coated mdf that the sled uses. To stop it from sliding around you could use a hook on the front edge or some magnets and cork rubber or other non stick material. Quote Link to comment Share on other sites More sharing options...
TomInNC Posted April 26, 2022 Author Report Share Posted April 26, 2022 Yes, I meant in length perpendicular to the blade. The miter gauge is removable, but using the sled definitely gave me more control of the cuts for large tenons on the workbench build. I swear I saw a video where someone had rigged a way to connect two miter gauges to create a two-handled cross cut sled that you could use to trim the bottom of doors. Can't seem to find it at the moment. Just planing a support board down and using magnets is a great idea. I already have some magswitches, so that could be done for very little cost. 1 Quote Link to comment Share on other sites More sharing options...
TomInNC Posted July 13, 2022 Author Report Share Posted July 13, 2022 I am gearing up to build the waterfall table in the guild. When Matt cuts the bevel for the waterfall joint, he uses a circular saw and an edge guide. In other videos I have seen, the makers use a cross cut sled on the table saw. I am leaning towards using the table saw since I think I will be a lot more precise than I would be with my circular saw. When I make the first bevel cut, the table will be roughly 7 feet long by 16 inches wide. This is obviously far too large for using the miter express, but I was thinking of using the approach Chestnut suggested above that would add support beyond sled's capacity on both the left and right side. Does anyone have experience with bevel cuts on a piece this large on the table saw? If so, do you think the table saw approach is better than using the circular saw? Unfortunately, there's no practical way to just test both approaches. Also, if I do make the support pieces for the sled, by far the easiest approach would be to just run 3/4 MDF through the planer until I get it down to the thickness of the incra sled. The information I've read on dimensioning MDF ranges from "it's no big deal" to "don't even think about it." For what it's worth, I am using the Powermatic 15 planer with the helical head. Am I going to totally wreck the planer if I dimension a few square feet of MDF on it? Quote Link to comment Share on other sites More sharing options...
G Ragatz Posted July 13, 2022 Report Share Posted July 13, 2022 Any reason you don't want to use a piece of solid wood? If I understood @Chestnut's suggestion correctly, you don't need a support that covers all of the table beyond the sled - just a strip along the edge of the table for the workpiece to ride on. Probably the narrower the better, to minimize drag. 1 Quote Link to comment Share on other sites More sharing options...
curlyoak Posted July 13, 2022 Report Share Posted July 13, 2022 https://www.infinitytools.com/incra-miter-5000-table-saw-crosscut-sled is a link to the incra 5000. The bed has built in hold downs. This will also cut wide pieces. I made several 23 plus inches crosscuts. Repetitive and accurate. If you need long and wide cuts that are dependable this is the least expensive way. PS if you need to roll the blade to an angle, the incra won't work. It is for 90 degree cuts only. Quote Link to comment Share on other sites More sharing options...
Mark J Posted July 13, 2022 Report Share Posted July 13, 2022 Isn't the 5000 a bigger sled than the express? Quote Link to comment Share on other sites More sharing options...
curlyoak Posted July 14, 2022 Report Share Posted July 14, 2022 On 7/13/2022 at 2:10 PM, Mark J said: Isn't the 5000 a bigger sled than the express? After looking at an online picture just now the 5000 clearly is bigger. Quote Link to comment Share on other sites More sharing options...
TomInNC Posted July 19, 2022 Author Report Share Posted July 19, 2022 On 7/13/2022 at 12:00 PM, G Ragatz said: Any reason you don't want to use a piece of solid wood? If I understood @Chestnut's suggestion correctly, you don't need a support that covers all of the table beyond the sled - just a strip along the edge of the table for the workpiece to ride on. Probably the narrower the better, to minimize drag. I do just need strategically placed strips to support the work piece. I guess I was concerned that the solid wood would be more prone to warping over time. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted July 19, 2022 Report Share Posted July 19, 2022 Just use a stand to the side of the saw to carry the additional length. Quote Link to comment Share on other sites More sharing options...
curlyoak Posted July 19, 2022 Report Share Posted July 19, 2022 With or without the incra 5000 I spray silicone on the friction points That makes the work feel smaller. I spray it under the moving panel of the incra 5000. On 7/19/2022 at 11:03 AM, TomInNC said: I was concerned that the solid wood would be more prone to warping over time. Make sure your wood is dry. Avoid wood from or near the center of the tree. If the work is to slide over a piece of wood I also spray that. Furniture wax will do the same as silicone. Quote Link to comment Share on other sites More sharing options...
TomInNC Posted July 19, 2022 Author Report Share Posted July 19, 2022 After I get the outrigger setup, are there any tricks for stabilizing the table before the cut? I've done cross cuts of maybe 18 inches on the sled, but those pieces were only maybe 2 feet long. I have a feeling it will be tricky setting things up to cross cut a 20 inch wide by 7 foot long board. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted July 19, 2022 Report Share Posted July 19, 2022 Clamp the work to the sled fence, make sure the outrigger is on plane with the sled, and do anything necessary to minimize friction. Should work like a champ. Quote Link to comment Share on other sites More sharing options...
Mark J Posted July 20, 2022 Report Share Posted July 20, 2022 One more suggestion. Set up your sled and work piece, but do a dress rehearsal "cut" with the saw off and the blade retracted. That way you can see if the operation is going to go smoothly. 1 Quote Link to comment Share on other sites More sharing options...
BillyJack Posted July 20, 2022 Report Share Posted July 20, 2022 On 7/19/2022 at 12:47 PM, curlyoak said: With or without the incra 5000 I spray silicone on the friction points That makes the work feel smaller. I spray it under the moving panel of the incra 5000. If the table has been wax pedistal and maintained , just waxing is all that's needed... Painters absolutely hate silicone in a woodworking enviroment.. Quote Link to comment Share on other sites More sharing options...
curlyoak Posted July 20, 2022 Report Share Posted July 20, 2022 On 7/20/2022 at 1:17 PM, BillyJack said: Painters absolutely hate silicone in a woodworking enviroment.. I love it and I paint. The silicone is completely gone when I do finishing. If you don't sand then there will be trouble. I always sand and NEVER had a problem. Maybe you need to sand more... Quote Link to comment Share on other sites More sharing options...
BillyJack Posted July 20, 2022 Report Share Posted July 20, 2022 When A person works on it it's simple, when several do it's not. If you get a board wet and wiperight off its fine, if you wet it and leave it you get different results. I keep silicone away from my car as well. Quote Link to comment Share on other sites More sharing options...
woodprox Posted July 30, 2022 Report Share Posted July 30, 2022 1. Make sure that the blade is properly aligned with the fence and miter slot. 2. Always use a featherboard to help keep the workpiece against the fence. 3. Use a push stick to keep your hands away from the blade. 4. Keep your hands clear of the path of the blade at all times. Quote Link to comment Share on other sites More sharing options...
gee-dub Posted July 31, 2022 Report Share Posted July 31, 2022 On 7/19/2022 at 1:02 PM, TomInNC said: I have a feeling it will be tricky setting things up to cross cut a 20 inch wide by 7 foot long board. Tom has probably gotten past this by now. I just wanted to add that for some operations bringing the tool to the work is better than bringing the work to the tool. If your material starts to surpass your equipment capacity clamp down the material and machine it in place. A hand saw, jig saw, or circ saw followed by a shooting board to true the cut. A guide and a circ saw with the proper blade, etc. We can fall into the habit of approaching everything with the same process; tablesaw, router, hammer and chisel. Different operations work better different ways. This may explain the wall full or jigs behind my tablesaw and router table 1 Quote Link to comment Share on other sites More sharing options...
curlyoak Posted July 31, 2022 Report Share Posted July 31, 2022 To add to gee-dub. I frequently make counters and tops with a bread board end. After cutting 1/16 more than needed, I clamp a straight edge to the work and run a router on the end for a perfect glue joint. 2 Quote Link to comment Share on other sites More sharing options...
BillyJack Posted July 31, 2022 Report Share Posted July 31, 2022 You should be able to do this with a panel sled Are you referring to a countertop with a bread board end? Quote Link to comment Share on other sites More sharing options...
TomInNC Posted August 1, 2022 Author Report Share Posted August 1, 2022 Apologies for not replying. Something popped up at the house that I had to attend to. Thanks for all of the suggestions. As luck would have it, a few days ago someone was selling a used TS 75 for a good price, so I picked one up. At least for the waterfall table, this should make taking the tool to the wood a lot easier as I didn't have a track saw before. 1 Quote Link to comment Share on other sites More sharing options...
legenddc Posted August 1, 2022 Report Share Posted August 1, 2022 I made a miter joint on a large board about 65"x20" and ended up making a new sled since it was too big for the miter express. I tried it with a track saw but the panel wasn't flat enough so the joints didn't line up. It's all in here if anyone else is looking. Couldn't you take the off-cut side of the Miter Express and put that in router table miter slot? That should give you the same height support and for free. Quote Link to comment Share on other sites More sharing options...
curlyoak Posted August 1, 2022 Report Share Posted August 1, 2022 On 7/31/2022 at 11:11 AM, BillyJack said: You should be able to do this with a panel sled I want better. Cleaning up the cut made by a sled on an 8/4 x 42" x 7' for example to me is crazy. Like gee-dub indicated on big work bring the tool to the work. I have made glue joints on smaller pieces on the table saw. My table saw does not have a slider. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted August 1, 2022 Report Share Posted August 1, 2022 Again you should be able to do this with a panel jig. Not sure what you would have to clean up? I used an Altendorf slider at work but a panel sled at home. 1 Quote Link to comment Share on other sites More sharing options...
