curlyoak Posted August 1, 2022 Report Share Posted August 1, 2022 On 8/1/2022 at 11:39 AM, BillyJack said: Again you should be able to do this with a panel jig. A laminated 2" x42" X 7' on your sled? I'm too old and feeble to manage that. That would weigh around 175 lbs. And 42" is much too wide for my 10" Delta. Not possible unless you have a jumbo size table saw. Imagine there are some sliders that would accommodate a wide and heavy crosscuts. I will always bring the tool to the work on large pieces like this thread has been asking about. I just cut it off with a skill type saw with a straight edge guide. I have a clamping straight edge for this work. And use the same edge with a big router and a bit that cuts 90 to the surface. I take a little less than 1/16". Quote Link to comment Share on other sites More sharing options...
curlyoak Posted August 1, 2022 Report Share Posted August 1, 2022 I have not tested the capacity of my new incra 5000. I have made some 23" crosscuts 3 ft long. 3/4" birch. Before I made the cut I rough cut the plywood first an inch bigger. The lighter it is the more control you have. And more control means more accuracy. Something I care about. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted August 1, 2022 Report Share Posted August 1, 2022 I just try and understand the can, can't and won'ts of a subject. I didn't have a slider for 33 years. I'm still trying to understand using a breadboard end on such a top.. 1 Quote Link to comment Share on other sites More sharing options...
