Hammer5573 Posted August 7, 2022 Report Share Posted August 7, 2022 I'm completing a grandfather clock made entirely of cherry. I experimented using a Lye solution (3 parts crystalized lye/one cup distilled water) to create a seasoned finish (looks something like Rosewood). I'm trying to decide what to apply as a finish. Typically, I French polish my pieces; however, this piece is so large that I don't want to use this technique. I'm trying to attain a high gloss finish and I'm not sure what to use ( poly, lacquer etc). I would appreciate your suggestions? 1 Quote Link to comment Share on other sites More sharing options...
Ronn W Posted August 7, 2022 Report Share Posted August 7, 2022 Your clock probaly has some nooks and crannies or, at leat, interior corners that are difficult to finish nicely with a rag or brush. I would lean towards a spray finish like laquer. Uneducated opinion - others here have more experince with spray finishes. BTW - Grandfather clock is on my bucket list. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted August 7, 2022 Report Share Posted August 7, 2022 I agree with spraying. Poly will amber the dark cherry a bit more, while lacquer should keep it a bit brighter. I've done that lye treatment on cherry a few times, it can create a stunning color. I bet that clock looks awesome, going to share some photos? Quote Link to comment Share on other sites More sharing options...
Hammer5573 Posted August 7, 2022 Author Report Share Posted August 7, 2022 On 8/7/2022 at 6:58 PM, wtnhighlander said: I've done that lye treatment on cherry a few times, it can create a stunning color. I wish that I had known that you had experience using lye because I made plenty of mistakes using it. Do you have any advice removing glue spots? When I use it in the future, I'm planning to spritz it with water before applying the lye; do you agree? 1 Quote Link to comment Share on other sites More sharing options...
Wimayo Posted August 8, 2022 Report Share Posted August 8, 2022 Equal parts of tung oil (or BLO), mineral spirits (or turpentine), and gloss poly. I used this on a cherry chest 25 years ago and it still looks great. Wipe on thin coats using a folded blue towel. Quote Link to comment Share on other sites More sharing options...
pkinneb Posted August 8, 2022 Report Share Posted August 8, 2022 Spray lacquer would be my choice Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted August 8, 2022 Report Share Posted August 8, 2022 @Hammer5573, use water, as you would to raise the grain. That's about as effective a method for finding glue spots as I can think of. But, I've notice the lye seems to either penetrate of get under the glue, somehow. The last project I used it on was an experiment, which I didn't clean of glue as thoroughly as I should, and the color darkened even under the glue. Here is a pic, wher I was testing handle shapes (handle & lid aren't finished). The cherry edges are very dark, as I used a pretty strong lye solution. The walls of the box are white pine, and you can't see any if the multiple glue spots that exist. Quote Link to comment Share on other sites More sharing options...
