Coop Posted October 13, 2022 Report Share Posted October 13, 2022 On 10/12/2022 at 8:17 PM, pkinneb said: Yes it is. I believe this came out either Shop Notes or Woodsmith That’s just cool! Lifts and all! 1 Quote Link to comment Share on other sites More sharing options...
Just Bob Posted October 13, 2022 Report Share Posted October 13, 2022 1 hour ago, pkinneb said: Yes it is. I believe this came out either Shop Notes or Woodsmith Shop Notes 128 March 2013. 1 Quote Link to comment Share on other sites More sharing options...
gee-dub Posted October 13, 2022 Report Share Posted October 13, 2022 On 10/11/2022 at 6:22 AM, TomInNC said: I guess I should have added that I have actively been avoiding projects that would require the use of a drill press, and I would like to try to expand my horizons a bit. The drill guide is serviceable in some cases (e.g., drilling straightish holes), but it is a pain to use to do things like removing waste with forstner bits. Ah. This is a different situation. You are wanting the tool in order to expand the things you are doing. With the price of the Delta 18-900 going way out of scope I would look to the Voyager. I almost shop drill presses as a hobby since they are generally so poorly made and so over priced. The early Voyagers rated very well with or without the tech stuff. Since it is so hard to make a quill go up and down accurately (read sarcasm) I would have to find something that rates equal or higher in the sub-$2k tier before I would be persuaded away. JMHO 1 Quote Link to comment Share on other sites More sharing options...
TomInNC Posted October 13, 2022 Author Report Share Posted October 13, 2022 Given the responses above, it sounds like my best bet is to find a mobile base that exceeds the base size on the actual press for added stability. Then, I should cut plywood to match the base dimensions and bolt the press base to the plywood. On commercial bases like the Portamate, are there pre-drilled holes for bolting down the plywood, or should I plan for needing to add those holes? Quote Link to comment Share on other sites More sharing options...
Mark J Posted October 13, 2022 Report Share Posted October 13, 2022 I can't see any holes in the 3550 I have, but they would be easy enough to drill. I am not sure how much larger than the DP I would want the mobile base to be; there has to be space for your feet. I did not attach the 3550 to my DP. Quote Link to comment Share on other sites More sharing options...
Popular Post fcschoenthal Posted October 14, 2022 Popular Post Report Share Posted October 14, 2022 On 10/12/2022 at 8:17 PM, pkinneb said: Yes it is. I believe this came out either Shop Notes or Woodsmith Man I miss ShopNotes. I need to build something like this for a "new" drill press I couldn't pass up. I've had a 12" Delta benchtop for almost 20 years and it still is doing great. Then I saw a 17" Craftsman on Marketplace for $20 that I couldn't pass up. I need to derust the column, but it runs strong and true. 3 Quote Link to comment Share on other sites More sharing options...
Just Bob Posted October 14, 2022 Report Share Posted October 14, 2022 1 hour ago, fcschoenthal said: Man I miss ShopNotes. I need to build something like this for a "new" drill press I couldn't pass up. Past issues are still available here. It is a great resource. 1 Quote Link to comment Share on other sites More sharing options...
fcschoenthal Posted October 15, 2022 Report Share Posted October 15, 2022 On 10/14/2022 at 5:07 PM, Just Bob said: Past issues are still available here. It is a great resource. Luckily, I have all of the past issues both physically and digitally already. I just miss all of the projects and tips that they put out. I haven't found that in any of the current mags. 1 Quote Link to comment Share on other sites More sharing options...
