Noah Posted October 23, 2022 Report Share Posted October 23, 2022 Hey so I’m using watch butcher block oil and finish also, I have done 3 coats so far and am debating on doing another but I wanted to ask if anyone knew if you NEED to sand it before you do another coat or if I can put another coat on without sanding… thanks for any help. Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted October 24, 2022 Report Share Posted October 24, 2022 Mfg. application instructions say to scuff sand between coats with 400 grit. I suspect you could skip that step and get away with it, but it is possible the second coat won't adhere well. That product is a tung oil / alkyd resin blend, which doesn't 'melt' into previous coats, like shellac or lacquer. Quote Link to comment Share on other sites More sharing options...
