TomInNC Posted January 3, 2023 Report Share Posted January 3, 2023 I assembled a floor standing drill press over the holidays. I put the press on a Bora mobile base. The press seems pretty stable, but since my kids are occasionally in the shop, I would like to add some extra insurance against the press accidentally tipping over. One thought I had was to connect a lift magnet (e.g., something like this https://www.amazon.com/VEVOR-Permanent-Magnetic-Lifting-Neodymium/dp/B091JSF6GN?th=1) to the back of the drill press. Then, I would run cable through a heavy duty eye hook in the ceiling and connect that to the magnet. Has anyone tried something like this before? Quote Link to comment Share on other sites More sharing options...
Wimayo Posted January 3, 2023 Report Share Posted January 3, 2023 Might work. I think I would also consider making the mobile base with a broader footprint. 2 Quote Link to comment Share on other sites More sharing options...
Popular Post wtnhighlander Posted January 4, 2023 Popular Post Report Share Posted January 4, 2023 Would it be simpler to perhaps replace some hex-head bolt on the machine with an eye-bolt, and tie off to that? Magnets can be tricky, having far less 'grip' in a shear movement, than in a straight pull. 3 Quote Link to comment Share on other sites More sharing options...
Tom King Posted January 4, 2023 Report Share Posted January 4, 2023 The magnet seems like more trouble, and expense than it would be worth. A piece of 1/4" yacht braid is plenty strong enough, and a carabiner to clip onto something up high on the drill press, or even just tie it around the column. 1 Quote Link to comment Share on other sites More sharing options...
TomInNC Posted January 5, 2023 Author Report Share Posted January 5, 2023 On 1/3/2023 at 9:51 PM, Tom King said: The magnet seems like more trouble, and expense than it would be worth. A piece of 1/4" yacht braid is plenty strong enough, and a carabiner to clip onto something up high on the drill press, or even just tie it around the column. After looking at it some more, this does sound like a much more efficient way to go. Now I just need to find a large diameter carabiner. Quote Link to comment Share on other sites More sharing options...
BonPacific Posted January 5, 2023 Report Share Posted January 5, 2023 If it's a motor-off-the-back style there's probably a spare hole or spot on the mounting bracket you could thread a bolt through. Quote Link to comment Share on other sites More sharing options...
