Hammer5573 Posted January 28, 2023 Report Share Posted January 28, 2023 Does anyone know if a profiling router bit that is at least 4” long can be purchased ..? Quote Link to comment Share on other sites More sharing options...
Hammer5573 Posted January 28, 2023 Author Report Share Posted January 28, 2023 To clarify the question above, I’m looking for a flush trim router bit Quote Link to comment Share on other sites More sharing options...
Mark J Posted January 28, 2023 Report Share Posted January 28, 2023 With a 4" long blade? That would be a tall ask, if you'll excuse the pun. Quote Link to comment Share on other sites More sharing options...
Popular Post JohnG Posted January 28, 2023 Popular Post Report Share Posted January 28, 2023 I certainly wouldn’t want to use a router bit with 4” cutting height. Can you start out with a bit with a bearing at the base and then finish from the other side with a bit that has the bearing at the tip? 2” cutting length can definitely be found. 3 Quote Link to comment Share on other sites More sharing options...
BillyJack Posted January 28, 2023 Report Share Posted January 28, 2023 On 1/28/2023 at 12:26 PM, Hammer5573 said: Does anyone know if a profiling router bit that is at least 4” long can be purchased ..? Is the 4” in total length or the profile itself? Quote Link to comment Share on other sites More sharing options...
wtnhighlander Posted January 28, 2023 Report Share Posted January 28, 2023 This is the longest flush trim bit I have found: https://www.findbuytool.com/products/spiral-flush-trim-router-bit-with-double-bearing?currency=USD&variant=44280589025570&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gclid=CjwKCAiArNOeBhAHEiwAze_nKAZFymhpFMrgS6LEfZkqZ7qiWQqiqtc1n5eD2URb2h-dO0BgFmugexoCeoMQAvD_BwE A little longer that William Ng's "Big Daddy" bit. Quote Link to comment Share on other sites More sharing options...
Hammer5573 Posted January 29, 2023 Author Report Share Posted January 29, 2023 On 1/28/2023 at 4:11 PM, BillyJack said: Is the 4” in total length or the profile itself? It’s the profile. I thought that maybe a bit with this length would be used in a professional shop. Quote Link to comment Share on other sites More sharing options...
Mark J Posted January 29, 2023 Report Share Posted January 29, 2023 Maybe on a shaper, but I think that would a bit much on a router . What is the project? Maybe there's another way to get what you want accomplished. Quote Link to comment Share on other sites More sharing options...
BillyJack Posted January 29, 2023 Report Share Posted January 29, 2023 Sounds like you need a planer/molder… Quote Link to comment Share on other sites More sharing options...
Calmudgeon Posted March 23, 2023 Report Share Posted March 23, 2023 On 1/28/2023 at 1:17 PM, JohnG said: I certainly wouldn’t want to use a router bit with 4” cutting height. Can you start out with a bit with a bearing at the base and then finish from the other side with a bit that has the bearing at the tip? 2” cutting length can definitely be found. Agreed. I don't believe I've ever seen anything beyond 2", and for good reason. You may find longer cutters in the shaper world, but I would only use those with a power feeder or a carriage that held the work piece and kept the hands *well* back. As John said, the solution is to perform 2 cuts, the first with the template on the bottom of the workpiece (assuming you're doing this at the router table) and the top bearing removed. Then replace the top bearing, flip the workpiece and ride the top bearing on the material you routed with the first pass. I've used this many times to shape 3" thick corbels for kitchen cabinetry. Just be conscious of when you're cutting against the grain (because on one pass or the other it can't be avoided) and adjust feed rate appropriately. I'd suggest doing the more difficult cut on the *second* pass so that you're assured of a smooth reference surface from the first cut. 1 Quote Link to comment Share on other sites More sharing options...
