gee-dub Posted February 20, 2023 Report Share Posted February 20, 2023 Hoping someone living near SoCal has an interest in turning. For Sale, Local Pickup: Delta 46-460 Variable Speed 12" Lathe with bed extension and tools / accessories. - $800. Retail for lathe and extension alone is about $1,260. 8 Drawer Base is Shop Made. You will need to bring help to load as I cannot assist due to health issues. This lathe was lightly used by my father for several years. He was in his 90s and so did not do a whole lot with it. It is available to pick up in the Riverside area of southern California. The machine is very smooth and surprisingly powerful for its size. There are two rests, a mounting plate, centers, drill chuck, and other odds and ends that will be included. There will also be included a set of medium quality, mostly HSS turning tools. Specs: Horsepower: 1-HP, 1-Phase, 120V, 60-Hz Speeds: 250-700, 600-1,800 and 1,350-4,000-RPM Swing Over Base: 9-9/16" Drive Spindle: 1"-8 RH TPI Thread Head and Tailstock Taper: #2 MT Tailstock Spindle Travel: 2-1/4" Length: 61-1/2" with Extension Height: 17-3/4" Motor Control: Electronic Variable Speed Swing Over Bed: 12-1/2" Index positions: 24 Distance between Centers with Extension: 42" Drive Spindle through Hole: 15/32" Self-ejecting Tool Rest: 6" and 10" Width: 11" I suggest replying via PM if you have questions or are otherwise interested. 2 Link to comment Share on other sites More sharing options...
RichardA Posted February 21, 2023 Report Share Posted February 21, 2023 Turning wood? Hell, I can barely turn around. But, that looks like a damn nice set up for someone. Good luck. Link to comment Share on other sites More sharing options...
Tom King Posted February 21, 2023 Report Share Posted February 21, 2023 That will be a good buy for someone. I'm still using an older belt swapping version of that one, and it does its job just fine. I don't do a lot of turning, but the need comes up occasionally. If I was closer, I would have bought that one, and all the chucks you were selling too. Link to comment Share on other sites More sharing options...
