Friends, as you see in the following photos this fine little table has developed a cupped top across the grain. I have a rough plan on how to fix it, but since between the cold and the holidays it will likely be a bit before I get in the shop, I thought I'd ask the if anyone has a better idea.
The top has a small square block both holding it to the spindle. The screws are little loose, but there is not enough of a gap between the square and the top such that tightening them up will significantly flatten the top. (I just noticed the screws aren't symmetrical, I'm not sure why.)
My thinking is get the top flat using a damp towel and some heat, and then attach two cauls to the bottom of the top, running across the grain, one on either side of the current square to try and hold it flat. I'd make the cauls as long as possible without them being visible from above and too visible from the side. Where the red lines roughly are in the image below.
Thoughts?
You could rout a dado in the table top and recess the cauls, so they'd be less obvious.  Some people use metal U channel for extra strength.  You could remove the block and route a dado for the caul closer to the center.
I'm just tossing out ideas; I'm nor saying these are good ideas.
What time of year is the top the most flat?  That might be the best time to try to "fix" the top.
It's a good looking table.  Does it need to be flat?  After all antiques aren't perfect.
On 12/22/2025 at 12:40 PM, Tpt life said:
I wonder if the finish schedule is unbalanced, leaving the bottom to take humidity on more quickly. I think some effort to balance might be called for.
Good question. It is a fairly thin finish, perhaps an oil. I can feel the grain with my fingers. I don't feel a significant different between the sides of the top (or the base) but the top definitely has signs of spills and other minor incidents.
I would hesitate to start applying more finish until I figured out what is on it, and based on past experience I have low confidence I can do that.
If you have a sense of how old it is, you can use that to make some deductions about the finish.
If it predates poly, then odds are pretty good it's an oil, or shellac. Or both.
One easy way to test if it's shellac is to rub some denatured alcohol on an inconspicuous area. If it quickly removes the finish, it's shellac.
On 12/26/2025 at 7:20 AM, Von said:
On the bottom of the tabletop is the following sticker. I don't see a date on it, but I did some searching with Google lens and found an example of someone selling the same table with a much more legible sticker. So is this table was made by the Consider H. Willett Furniture Company of Louisville, KY. Based on other posts, the sticker probably dates it very early in the life of the company, in the 1930s. It's walnut which is unusual for Willett, who did mostly cherry, but given the pricing in this ad, and similar ones I've come across, it's not of any significant value.
Looking into how Willett finished, they apparently finished their furniture with "a wax finish developed after years of research" which seems consistent with what I see on my table.
Good sleuthing @Von! I noticed that and was wondering if it was painted on or a sticker. I wonder if they had stickers in the 30s? No idea.
Edit:
I missed the obvious, that if the table predates stickers, they certainly could've made one using paper and adhesive. Sometimes my responses come before the critical thinking kicks in. Lol.
Edit:
Yeah, I used "sticker" loosely. Paper with glue is probably accurate.
Back to the original topic, I expect I will try to do a little clean up of the surface and apply some wax once I have it flat again, at least on the top of the top. It has one good scratch I'll try to address when doing so.
Thanks for asking the question that prodded me to research. It was fun learning a little more about the table even if it's relatively pedestrian.
BTW, I thought my wife brought it into our house, but she assures me I did, so I really have no idea of its history.
