@gee-dub, since you brought up the issue of moving heavy stuff as we age, let me ask about lumber storage. How do you manage to get heavy planks down from ladder heights on a wall-mounted horizontal rack??
I ask, because LOML would prefer I move my stash out of the garage, where I have a conveniently high ceiling, and can stand boards on end for easy access at floor level. Anywhere else I go will need horizontal storage like yours.
The title of your thread is dramatically underselling what you're making here. I expected to see a basic rectangular picture frame with a mirror in it, not this crazy design. Really looking forward to seeing how this turns out. It looks like it will match your other furniture very well!
  • Thanks 1
With regards to the guides on the bandsaw, to each their own of course, but I set mine not to guide the blade but to reduced the amount of exposed blade I might accidentally run into.
18 hours ago, gee-dub said:
I noticed that I did not even bother to adjust the height of my guides.
Was that a onetime thing, or do you usually keep the upper guide all the way up?
If I'm not doing curves I generally don't worry about them.  Obviously the thrust bearing position is important so you don't ruin the set of the teeth.  It is just that if I have been doing tall resawing and later do shorter ones I just don't really think about it :)
So true and thank you Von.  I am a bit of a safety nut and your point is 100% valid.  I need to reset my "getting jaded" meter :).  Getting too comfortable around these man-eaters is what often leads to bad things.
On 4/7/2026 at 2:30 PM, fcschoenthal said:
I think @Coop meant your tablesaw outfeed. My guess is that it's about 4'x3'.
Correct and thanks. I currently have a Husky adjustable height table in another part of my I shop and I think at the price, this might be best for the out feed and customize it with drawers as @gee-dub’s. Sorry for the hj.
I use French curves, too.  Having found a section of one of the curves with the desired curvature I wish I could find a way to mark the beginning and end points of the segment for later use.
I stick piece of Scotch tape on and mark them with a fine point felt pen. Definitely an extra step but when trying to match multiples . . . worth it.
Mine are plastic. I just use a sharpie to mark the segment. It doesn't rub of too easily (although you have to be somewhat careful) and will clean up with IPA nicely. The tape would definitely work and would probably be less steps and cleaner.
Now if I could only remember that the next time I use them.
