TexWood Posted February 8, 2011 Report Share Posted February 8, 2011 OK, I'm building a Wall-Hanging Jewelry Cabinet, so my dimensions are a little smaller (approx 24" X 17 3/4"). I designed the doors to be 3/4" thick, but after milling the stock it seem a little beefy for the 1 1/2 & 2" rails and stiles. Since the doors will be 22 3/4" tall, does anyone see any concerns if I reduce the thickness to 1/2"; or maybe I should only have a single door with wider components and keep the 3/4" thickness. If you would like to provide some input, you can also reference the attached SketchUp file (be kind, this is only the 2nd design I have done in SketchUp...lol). Thanks, TexWoodGG JB_02.skp Quote Link to comment Share on other sites More sharing options...
AMarshall Posted February 9, 2011 Report Share Posted February 9, 2011 Kyle, that's a pretty dang good model for your second time out! Nothing to be ashamed of there, buddy! I like that the lower rails are taller than the upper rails. I think you should keep the double doors, but I see what you mean about them looking a little thick at 3/4". With a 1/4" thick panel in the door, stiles and rails that are 1/2" thick would only have 1/8" of material left on each side of the panel groove, which sounds a little thin to me. How about splitting the difference and going with 5/8" thick rails & stiles, so you have a little more support for the panel? Quote Link to comment Share on other sites More sharing options...
TexWood Posted February 9, 2011 Author Report Share Posted February 9, 2011 Thanks for the SketchUp compliment oh great one :-) I do have this new fangled drum sander I bought last month, so I could conceivably reduce the thickness of the pannel. What I'm most concerned with is the door eventally bowing due to only a 1 1/2" X 1/2" stile that is 23 3/4" long. So I think your 5/8" idea maybe the ideal solution. Thanks again, Kyle Quote Link to comment Share on other sites More sharing options...
