Tailvise Instalation and dog holes on a solid 12 inch slab?
So I posted this in the guild hall which is probably the wrong spot.
but I'm not sure how I'm going to procede I'm building my roubo top out of 2 12"x5"x100"ash slabs and I'm not sure about the Tailvise Instalation.
Should I just hand mortise the dog holes and cut out the area for the tail vise in the 12 inch slab and if I do
Do I still need an end cap? Or is the end grain of the slab not going to be strong enough for the vise?
Or just laminate the dog holes on to a narrower slab like the plan says with an end cap?
Advice please
I would say for the sake of simplicity, make separate front laminate and dog hole strips. You have a big slab for the main body of the front slab so that's saving you a lot of work. But this vise should really be installed with an end cap. The dog hole strip, the front laminate, the end cap, and the vise are all intimately associated with one another. So I think it is best to have those pieces as "add-ons" to the slab so that you can follow the included instructions.
Your right thank you
it would would be a shame to screw up a big piece of lumber and not have what I need.
I'm working 9 inch slabs myself, so I'll be taking the same approach as recommended by Marc. Also, I'm using some nicely seasoned, rock hard Douglas Fir for the top, but I was considering using soft maple for the laminate, end cap, chop and deadman.
yeh i was kind in a rush yesterday to figure this out myself because i had to let my lumber guy know what size lumber i wanted. So how i was going to do the front slab was an issue. as in do i order a 12" slab or an 8" slab for the front.
im definitely going to put an endcap on like mark suggested but i may try to mortise the dog holes in the 12 solid slab, i can install a endcap still with the dovetails to support the vise.the bonus is if i mess up i can just cut it down the slab to the plan specifications @ 7 13/16 and glue the front dog-hole strip and front laminate on.
im looking forward to the challenge.
Why not use round dog holes instead? Hand mortising all those square holes sounds like a pain in the neck. You could eliminate the dog hole strip, and just incorporate this into the main slab of the front. If you switch to 3/4" round dog holes you could just drill them in the main slab.
I agree that you should have an endcap, mostly because the forces at play with the tail vise could overwhelm the end grain in the slab. But I'd be tempted to try to eliminate the laminate strip and just hog out a big groove for the tail vise with a router. If you use the sliding (Option 1) endcap design you could still use dovetail joinery, and the whole front would be a solid slab.
Yes your right it would be more work but as alot folks here have pointed out a bench like this is worth the extra effort.
I can still do square just start by drilling 1st then I'm just cutting corners and I can still make my own dogs this way.
I have 2 benches now both with round holes and I'm not super happy with them.
I believe option 1 is the right way to go also.
Besides I really prefer the hand work aspect of builds.
There's just something zen about hand work for me
