Dust Collector Filter Upgrade
I have a 2hp Grizzly Cyclone dust collector supporting my shop for over 5 years. I recently had a situation where the plastic bag came loose. I reattached it, but noticed that when the collector was running the pressure on the bag was quite high - not quite a basketball, but harder that a well inflated balloon.
Even though I have been using the cleaning brushes in the filter regularly and occasionally using compressed air, the filter had clogged up to the point where it was costing several pounds of static pressure. Rather than replace the cartridge filter, I decided to replace it with a bag filter system.
I purchased 8 bags measuring 6 inches in diameter and 64 inches long and built upper and lower plenums to connect them. The upper plenum mounts directly on the side of the collector and the lower one sits on the floor. Bag filters gather a cake of dust on the inner surfaces that falls off when the pressure drops. A little shake helps the process. The dust collects in the lower plenum, hence the clean out slot and cover.
With the new filters in place, the back pressure is minimal and the air flow in the system has easily doubled. The only downside is the increased airflow in the ducts increased the noise level in the shop.
PS - I can't seem to get the last picture to rotate. It shows correctly on my computer and dropbox.
Very cool hack of the Grizzly Mike! Do you have any way of measuring to see if you really have gained improvements in filtering? Particle meter or anemometer? On another forum we had done a collective purchase of a particle counter... wish I had gotten in on it as I could have used one when I was building a ambient cleaner.
Unfortunately, I don't have access to the instrumentation to do a scientific analysis. The only data points I have are:
1. The difference in back pressure, as measured by the pressure on the bag under the filter and on the tubes in the new filter is significant.
2. The first time I turned it on, I could hear all the chips that had settled in the pipes moving to the collector.
3. I can now leave several gates open and still get adequate pickup. Before the change, if there was a second gate open, the planer would not get cleared properly.
