Gel Coat Stain/Danish Oil finish problem
I am making a bookcase out of cabinet grade maple plywood. I created a test strip of different color stains to see how they would look from a pieces of scrap plywood (fortunately, otherwise I would be crying and out several $$$ for new plywood).
Here is the problem: When I applied the Watco Clear Danish Oil, the cherry stain was completely lifted off the wood. The other stains did not do this.
I had applied these stains, in my air conditioned basement. I do not have a humidity problem in the basement.
The steps I followed are:
  1. Applied one coat of Zinnser's SealCoat. Allowed to dry several hours.
  2. Applied two coats of the different Gel stains. Allowed to dry 12 hours
  3. Applied one coat of Watco Clear Danish Oil, wiping it one with a soft cotton cloth. Immediately, the Georgian Cherry stain lifted off the wood and onto the rag.
  4. The other stains did not lift off, but remained on the wood.
Any insights into why this happened would be greatly appreciated.
TIA
Earl
Stains have a certain amount of binders that let it hold itself onto the wood, or better put, "stick" to the wood. So when you applied the second coat of stain over top of the other. The stick was greatly reduced because of the lack of mechanical bonding. Nothing to hold on to. So when you wiped the topcoat over the stain, in fact, it re-wet the stain loosening the bond, thus removing it completely.
Next time try mixing the two stains together and applying as one (making sure both are compatible and from the same finish manufacture) or if its a light and dark thing. Use a sealer between coats of fully dried stain. And make sure your stain is completely dry before top-coating. Get the first coat of finish on as quickly as possible and don't over work it, let it dry good and this will seal in your stain ready for more coats of finish.
-Ace-
Thanks. Essentially, need to let it dry longer.
Will try this and see the results.
Another thing to keep in mind is that Danish Oil needs to absorb in order to cure properly. If the surface is sealed, the oil/varnish blend will just sit there and remain tacky for a loooong time. So after one coat of shellac and two coats of gel stain (which likely contain binders), the surface is already partially sealed. This combination will nearly always cause drying issues for Danish Oil. I would suggest using a good wiping varnish instead or cut out the shellac step.
