Poly over paint over stain - Help!
At the direction of the design committee (the Mrs.) my sons and I are working on a couple small-to-medium projects for Christmas presents. For 2 of them, she wants us to customize them in a specific way. She wants them stained, then have my oldest do some stenciled painting on them, then poly over to protect them.
Assuming worst case scenario, I'd be using readily available, home center finishing materials. That means oil-based stain, followed by water-based paint, followed by oil-based poly. My general finishing philosophy so far has been "keep it simple as possible so you don't screw it up."
I have no idea if mixing bases like this is good because putting on the new finish won't react and mix with the underlying finish, or if it means nothing will stick, and I'll have a mess.
Anyone have any experience doing this? Any pointers? Is this a job for a 1lb. Cut of shellac between finishes?
Appreciate any help.
In this case, I'd probably use a 2 lb shellac coat over the stain, either FS Seal Coat, or from a Zinnser clear spray bomb.
After the paint, I'd probably use a water based clear, to avoid yellowing the painted work.   I'd prefer spraying the first coat of clear, to avoid messing up the paint.  After that, you can wipe or brush....  Spray cans are fine, and both WB and oil based clears are available in them...
I'd suggest prepping a decent sized scrap board, staining it, sealing it, and adding a few stripes of the paint you plan to use.  Then, do 1/2 with oil and 1/2 with WB clear.  This will prove all of your products as compatible, and let you choose the clear that looks the best.
Finish compatibilty - everyone's favorite finishing topic.
Here is my suggestion
1) stain
2) barrier coat of dewaxed shellac
3) paint
4) water base poly
I say water base for two reasons.  1) not sure how well oil based poly will stick to latex paint and 2) it will give your project a yellowish color.  You green christmas tree will end up brownish and your white snow will look like a dog peed on it :).
Make sure the stain is dry.  It takes a while for oil stain to fully evaporate and off gas.   So even it if feels dry to the touch I'd wait a day or two before shellacing.  The shellac dries quick so you can get on to painting right away.    I think they sell aerosel shaker cans of minwax polycrylic, I'd use that for a top coat because it will be quick and easy to apply a nice smooth finish with no brush marks.
hah, he beat me to it but it looks like we are on the same page.
Awesome guys. Thank you very much. No shellac between the paint and water based poly?
water base poly should adhere fine to latex paint (assuming that is what you are using).     If you are using crafty type kids' paints like crayola tempera paints I don't know exactly what is in them so do a test board to be sure.
if you can lightly rub the surface with a very fine synthetic steel wool without messing up the kids' stenciling, it might give you a nicer finish and create better adhesion for the top coat.
  • 26,009 Total Members
  • Joseph b Newest Member ·
