woodhack Posted October 10, 2010 Report Posted October 10, 2010 I was cutting a sheet of plywood yesterday and after I had finished the cut I noticed that the guide fence had wandered about 1/4". This is the first time it had happened and I checked the bottom of the guide rail and I noticed the rubber strips were a little slippery. I couldn't find a replacement on the Festool website for the rubber strips although I do see a replacement for the splinter guard. Has anyone else had this happen and does anyone have any idea how to get my guide rail to be sticky again or should I spring for the clamps. Thanks in advance. Quote
PaulMarcel Posted October 10, 2010 Report Posted October 10, 2010 I rarely use the clamps since the sticky underside is sticky enough. If you have downward pressure instead of "into the guiderail" pressure, you should be fine. Sometimes mine get slicker than I like. Just blow the underside with compressed air. Or brush it. You just need the surface dust knocked off. Also, if you want clamps for the rails, DeWalt makes a quick-grip style clamp that works in the Festool guiderail (but not the MFT). I like it better than the Festool clamps for clamping the guiderail since it is so much quicker. Quote
ztifpatrick Posted October 10, 2010 Report Posted October 10, 2010 I was cutting a sheet of plywood yesterday and after I had finished the cut I noticed that the guide fence had wandered about 1/4". This is the first time it had happened and I checked the bottom of the guide rail and I noticed the rubber strips were a little slippery. I couldn't find a replacement on the Festool website for the rubber strips although I do see a replacement for the splinter guard. Has anyone else had this happen and does anyone have any idea how to get my guide rail to be sticky again or should I spring for the clamps. Thanks in advance. I"ve always used the clamps myself. You can definately buy replacement rubber, I've seen it at the Festool dealer and I've read about it in the manual, but I wouldn't rplace it unless its damaged. Get some clamps, that way you can be sure your cutting on the line. Quote
atomicmike Posted October 11, 2010 Report Posted October 11, 2010 The replacement part is called a "Non-skid strip", and the part number is 485 724. If it's slick, I'd definitely want to replace, though I also second the advice to use clamps whenever you can. Quote
Gregory Paolini Posted October 11, 2010 Report Posted October 11, 2010 Also, keep in mind that there are two styles of Festool clamps - There are the standard screws type clamps, as well as a quick release style, similar to the bessey klikclamps. The latter are the type I own, and it doesn;t get much faster than that. Best, Gregory Quote
