An alternative to Tung Oil.
I almost always use tung oil as my 1st coat on most furniture I make. I make outdoor stuff, benches, tables, chairs ,etc. and I mostly use red cedar (eastern and western), oak (red and white) and occasionally pine.
After the tung oil I sometimes stain but usually just apply several coats of a marine spar varnish, usually epathanes.
My problem is the yellowing after a year or so. I do like that soft aged look on most stuff but some things I want to keep the original contrast of the sapp and heart wood.
By the way, not all of the stuff I make is used outside and a lot of it does not have exposure to direct sun, so I know it's not the sun and I know It's not the epathanes because I used it on some of my indoor furniture in my basement and it still hasn't yellowed. So I'm convinced it's the tung oil.
Any suggestions what to use to pop the grain like tung oil does but doesn't yellow?
Thanks.
Blonde shellac or a neutral stain base will help pop the grain. sanding to a higher grit will also help. You will start to burnish the denser parts of the grain, causing some contrast.
Thanks Mike. So since a lot of my stuff will live outside, at least during the summer months is a shellac an appropriate choice for stuff that may be exposed to sun and rain ? I guess since I'll be covering it with varnish right ?
Also, when you say "neutral stain base" do you mean like a sanding sealer?
