Advice on top coat for red oak rolltop desk
I’ve started building a roll top desk made from Red Oak and I’m looking for advice on a top coat to use after I have stained the wood.  Since the desk has so many raised panels I plan on finishing most of the pieces before I glue it up.
I’m thinking about using shellac as the top coat.  I have a good quality HVLP gun and a large shop away from the house so there is a lot of area inside and outside to spray.  I’ve used shellac before but always wiped or brushed it on.  So I’m looking for experiences/opinions/suggestions on using shellac sprayed on vs brushed on.  I know spraying has a fire risk so I would need good ventilation if I sprayed indoors.  Is there a water based finish that would be comparable?  I’m not a very big fan of polyurethane but I’ve honestly never used it for a nice piece like this.  I’ve used Tung Oil on a different project but found on oak it would seep out of the pores and leave little shiny spots when it dried.
I have a long way to go before I can start finishing. Was nervous about the raised panels but after doing one side I'm ok with it now.
A desk takes quite a bit of abuse.  If it wasn't a roll-top I'd probably recommend poly (no reason not to be a fan...looks great when done correctly :)), but I agree spraying would be a million times easier assuming you have a tambour lid...nightmare to brush or wipe.  I might consider lacquer for a slightly tougher finish than shellac.  Use satin lacquer or flattener in your shellac for the final coats...gloss and semi-gloss looks pretty bad on oak.  Water-based is an option too.  I wouldn't wanna spray anything oil-based, but it's been done.  Shellac is a fairly fragile finish for high-abuse pieces, and you might find yourself in need of a refinish sooner than you would like.
15 hours ago, wtnhighlander said:
Not a sprayer myself, but I hear shellac sprays well.
Are you comfortable with coarse, open-pored grain of red oak? Or do you plan some sort of filling the grain before spraying?
I like the open pore look, however I am kicking around the idea of filling the grain on the main flat top surface.  Though I've never done any of that before.
I'm glad you mentioned the flattener for the shellac.  I also don't like the glossy look.  This desk won't get very much abuse.  It will be more of a show piece.  I'll put stuff in it but won't sit at it much at all.
