Deal on shop heat, and cooling
 I just bought a 6 year old, 6 ton single phase gas pack, for $500, that works fine, and has never needed any repair. An HVAC guy that I have done some favors for, called me, and asked if I could unload it off his trailer with a loader. I asked him if he had plans for it. He said no. I asked him what he wanted for it, and when he told me, I told him we could unload it right here. It's going in the mechanic/metal shop building that has only had a wood heater.
I bought a heat pump, a while back with a similar deal, that I had planned to use, but found a better use for that.  I didn't really want to run electric heat strips to keep the shop warm.
Just unloaded it.  I know it's a poor picture, but I realized, while I was on the tractor, if I didn't take a picture while I thought about it, I'd forget to take one.
I need to run a 60 amp circuit for it.  I have a 100 amp subpanel on that building, but will run a separate circuit from the main panel on a pole a hundred feet away.  That way, I can run the AC if I'm also running a welder.
The guy may have gotten it for nothing, from a building being demolished, but I didn't try to talk him down on price.  I was glad to get it for $500.
I slid it out of the back of his trailer, lowering it onto a 4x6 on the ground.  Then hooked it up like this, lifted it, he pulled the trailer out from under it, and I lowered it onto another 4x.  We'll worry about installing it later.
The supply, and return outlets are about 28" square.
I was just out looking at this unit.  It's Big.  I think it's about 4 feet tall, and 4x5 feet width, and length.  The fan motor is a 1-1/2hp Baldor.
Change of plan on the wiring.  I can buy 100 amp aluminum service entrance underground wire for about the same thing as no. 6 UF, so will put another 100 amp subpanel next to it, and use the breaker to it as the nearby cutoff.  Then I can pull other stuff out of this box, if I need to.  There was a power pole here already, about 100 feet from the building, with a 200 amp service on it, that only feeds a 100 amp subpanel to that building.
Right now, the plan is to build a small deck for it, and let it blow right into the building about 5 feet high.  That will keep it from taking wall space inside.  I'll run a return duct up high.  That'll make it a little trouble to change filters, but it won't be used That much anyway, and will be right beside where I store all the ladders anyway.
The building is 24x40, with 12' walls, but the roof has a strange gambrel framing, under the gable framing that lets me raise a full sized dump truck bed inside-not sure of the height of the high part.
I had quit doing fiberglass boat work, when a tornado destroyed my shop for that in 1988.  I never wanted to do fiberglass work again, without a really strong air conditioner.  Cool it down to 65, and you have all the time in the world.  Then raise it to normal, and let it kick.
