ernie34 Posted May 29, 2011 Report Posted May 29, 2011 Hi everyone. Just picked up a hardly used 34-474 contractors saw.I also own a PM66.but my question is on the delta saw.the previous owner said the only issue he had in the few times he did use it was the blade lift mechanism binding. so i figured it was just a lubrication problem which was no problem since i intended to field strip it and get it all ready.Well i found something interesting and confusing.Hopefully someone who is familiar with this will understand. the evelation shaft i'll call it (for lack of the real name)goes thru the front trunnion has a nut (on the back side) of the trunnion that just floats there???. first thing i found odd. you can't even snug it because if you do it binds in the trunnion.Regardless of lubrication.The next and biggest problem is. the reason it binds when turning,is the end of the pin opposite the handle is machined down for the rack type gear that meshes with the big gear that raises the blade. the machined area for the small gear is not even close to the center of the pin. so when you rotate the shaft the small gear comes almost out of the big gear and when you turn it 180 it goes so deep it bottoms in the big gear. (Hense the binding. it's not bent the shaft where the small gear goes on if way offset to the center.Manfacturing screw up???. seems unlikely.anyone ever see this. Thanks Ernie. (New Member)If necessary i can post a pic of the pin. Quote
Sac Posted May 30, 2011 Report Posted May 30, 2011 If you had some pictures so that we could see what you are talking about, it might help.. Quote
