Jsestrich Posted June 13, 2011 Report Posted June 13, 2011 Hey all, I am new to this forum but have been watching all of tww videos I can. Anyway, I just bought a old delta 37-220 6" jointer that is in really good shape. I sat down to calibrate everything and started with the pulleys. I was shifting the motor pulley in and out trying to get it to line up but every time I rechecked with a straight edge it was off. I finally reached up and felt the cutter pulley and it shifted. No wonder I could not get them to line up. The seller told me the bearings have just recently been replaced. The cutter shifts front to back about1/8" if you push/pull on the pulley. How do I tighten this up to stop the movement? Thanks in advance Jonathan Quote
Jsestrich Posted June 14, 2011 Author Report Posted June 14, 2011 Hey I figured it out, they used two different sized bearings when they replaced them. The smaller one I think is the wrong one. It is the same amount smaller as the amount of slop I have. Quote
nateswoodworks Posted June 16, 2011 Report Posted June 16, 2011 {I guess I would need to see a pic. Good thing you found it!! Please keep us posted. Nate Quote
Jsestrich Posted June 16, 2011 Author Report Posted June 16, 2011 Hey Nate It turns out the bearings were replaced with 6202 and 6203 bearings which I think are the correct ones for a newer model 37-220. However I found on OWWM that I need 87502 and 87503 bearings which have an extended inner race. These bearings will be about 4mm wider combined. I checked the gap I need to make up with my calipers and it is really close to 4mm. Delta wants $58 a piece for them but I found them local for $22 and online at Bearings Direct for $7 and $8 a piece. I have them ordered so I will let you know how it works out. Quote
