Bosch MultiX Blade Life (or Fein Multimaster or Sonicrafter or whatever...)
Hey gang. I picked up the Bosch MultiX oscillating tool to cut holes in my house, which consists mostly of plaster and lath interior construction. The tool seems to work pretty well, but the blades just don't last long at ALL.
I'm using it to make plunge cuts, once to do a duct for my stove exhaust, once to do a new wall outlet. Each time, I've visibly worn the teeth down before I was finished with the job. I'm using the rectangular blade, and doing plunge cuts through the wall. I don't think I'm chewing on nails.
Is there something wrong with my technique? Is there another blade I should be using? Am I using the wrong tool for the job?
Help a noob out. : )
Short of something like a SawzAll, here’s one possibility. I can’t tell you anymore about them than what’s in the explanation at the top of the page. Check out the blades listed in the group at the bottom of the page as well. They talk about a “Storm Series” blade with a titanium coating. I see that’s in the list, and while expensive it does cost less than the carbide or the diamond blades, although I don’t know how long it will last compared to the carbide or diamond blades.
Also, here’s another possibility. I’ve copied and pasted a comment from from a FAQ on their site regarding cutting through plaster and lath walls. Here’s the link to the diamond blade attachment they refer to.
“What’s our pick for cutting through plaster & lath?
Our universal bi-metal saw blade will be a good choice to cut through plaster, lath and all those little nails along the way but the lifespan of your blade will be reduced due to the abrasive qualities of the plaster. If this job is eating up too many of your blades try using our diamond blade attachment. It is designed to cut plaster, lath, backer board, tile and other hard materials.”
Hi, Onboard. I like the oscillating tool for this particular job, rather than a sawzall, because it's easier to cut a clean straight line, when it cuts.
I was using a Bosch universal blade, but the teeth just get ground to nubs before I've even finished my first plunge cut.
I need to see if the Fein blades fit on my Bosch...they've been at this longer, maybe they've figured it out.
Plaster is hardcore brutal on blades. I went through a bunch of them, recip and circ, on my dad's kitchen rehab last year.
Do they make any kind of masonry blade for the MultiX? That's what I'd look for...something that could cut through concrete.
  • 3 months later...
Imperial makes much tougher blades for a lower cost than the Fein blades I had been using. And plaster is brutal on any blade, use a carbide blade if possible.
