What's a good first project for a hand tool wood worker?
I started one project (a small box with 1/2" poplar) but wondering if it is the best subject. So what, as a general rule, are good first projects for the new woodworker using just hand tools?
Specific plans or general suggestions would be appreciated.
TIA,
Tony
A box is a good first project because it is small. However, you should avoid making one that is too small and you should definitely avoid complicated joinery like dovetails for your first project. Instead, use this first project to focus on accurate layout, accurately sawing to a line, and simple joinery like rabbets and butt joints. Take a look at the style of boxes made in the 17th century. These boxes are often called bible boxes today, but they weren't called that in the period. They were just boxes and they were used to store all kinds of stuff. They were commonly heavily carved in the period, but they don't have to be. There's no reason one can't be made without the ornamental carving. Take a look at this article on making a true reproduction of a period box: http://pfollansbee.f..._box_articl.pdf. Use it as a reference for the design and joinery, but don't start from a log like Peter does for the true reproductions. Since you aren't going to carve it, use a piece of kiln dried 1x12 from the home center.
They are rougly about 18-20" long by about 10-12" wide by about 6-7" high. They are joined with nothing more than rabbet joints and nails or wooden pegs. Glue can be used if desired. Use a 1x12 piece of oak, poplar or pine from the home center and you won't need to glue up any panels for the top and bottom. However, using the wide board will give you practice with crosscutting and ripping.
It may seem like a fairly simple first project, but it has the potential to teach you a lot if you pay attention and let it. Here are just a few of the skills it will teach you:
  • Proper layout and marking
  • Straightening & squaring board edges with a plane
  • Crosscutting to a line
  • Ripping to a line
  • Cutting rabbet joints with a saw and chisel
  • Reading grain direction
  • Boring with a brace and bit or hand drill
  • Planing a simple chamfer (you can use this as a decorative edge treatment for the top and bottom of the box to soften the sharp corners)
  • Squaring a box/case
  • Nailing
These are all basic hand tool skills that will be used on every project you ever build by hand and in my opinion they are plenty to take in on a first project. This is why I suggest avoiding complex joinery on a first project. It's hard enough to take in the basics when you haven't done a project before. Adding complex joinery will just result in information overload causing you to glance over a lot of these basic skills and potentially not remember them. So focus on these skills with a simple project like the nailed/pegged box I linked to and talked about above and you'll be off to a good start. If I were going to teach a class on hand tool basics for beginners, this would be the very first project I had my students build.
