How do I color match a finish?
I previously posted in the refinishing thread to get some ideas, but after further investigation I think my question should be posted here.
Here is my thread:
What finish should I use that will be durable under higher heat and sunlight but not really weather. I was thinking spar urethane? And, how would I ,or could I, match the color of a chip that I have from the previous finish.
I am planning on stripping the current finish and not staining the wood. Any idea would be appreciated.
Thanks
If you're looking for a good fix and not a great fix you could try gluing the piece back on, fill the cracks with a clear epoxy and then sanding the whole thing with something like a 320 grit just to make the surface consistent then hit it with a high gloss lacquer. that would eliminate the need to do a color match and save a whole lot of time. this is dependent of the fit of the piece that fell off of course..
If that is not adequate, I would match the wood type, build a new piece and match the color with a died lacquer I have found that most production car and cabinet pieces are not stained and then finished. They are tinted finishes (lacquer) to save time! this needs to be sprayed to my knowledge. I have my finishes matched by the guys at wood finisher depot a place in Houston. It takes a lot of bottles of dye to make the correct color match in most cases and I don't do enough of it to stock them all. on occasion i will tint my own with stain that I have color matched at Sherwin Williams. This gets it real close and I have not had any adhesion problems to date.
any way those are all the ideas I have, hope you have good luck.. let me know how it turns out
troy
Troy,
Been a busy weekend so my apologies for the long time reply. You are spot on with the analysis of the finish. Mercedes does not stain the wood, but they do use a tinted lacquer. That piece that I posted with the chip missing is actually just the finish and the lighter piece is the intact wood veneer, thankfully none of the wood is damaged. The photos of the piece with the 4 hole slots was taken out and has been put back in so I don't have to create new pieces, just have to find a way to match the colors.
So your suggestion of using a clear epoxy would be the way to go for durability, but the veneer underneath is way to light so my only option is tint the finish or stain the original wood. Hmmm, tough call. I really like the Sherwin Williams approach with an epoxy finish, that could work real nice.
Thank you for the suggestions. I have a couple of spares from a parts car and I will try my luck with those before tackling the pieces in my car. I'll let you know how it turns out and post some pictures. I know that this isn't furniture or cabinet building, but it is wood and I don't know a better place to ask!
Todd
  • 26,009 Total Members
  • Joseph b Newest Member ·
