Plane blade edges folding/denting on knots and end grain
Hi Guys, first post here after lurking for a while.
I recently picked up an old Record #7 plane. Made in England, probably in the 1960s with the original blade.
I sharpened up the blade with a 25 degree angle and started taking some nice shavings from some old douglas fir softwood :D
Then is tried some passes on some harder knotted pieces of timber and noticed the plane stopped taking nice shavings and would barely bite into the timber. On very close inspection, I noticed the blade edge was now dented and folding over. Thinking it might be a bad/soft blade, I tried similar cuts with my old Carter #6 (Made in Australia) on some similar knotty timber and end grain with similar resulting blade damage. I have mostly been working with soft woods to date so haven't really experienced this before
I know the answer is to use a higher angle when sharpening the blade but I wasn't expecting to have to do this. Are old blades from the 60 and 70s typically this soft and would new Hock blades or similar be much better? I would prefer not to come up with the extra cash.
Are there any disadvantages to using a higher sharpening angle since it is bevel down so that face doesn't meet the wood? I assume there is otherwise higher angles would always be used
Any suggestions would be appreciated.
might be that the iron wont ever hold an edge if its denting and you are looking at frustration every time you use the plane. i'd just go hock he sells a good product.
Increasing the bevel angle to 30° will help to strengthen the edge. You can do this with a secondary bevel. No need to regrind the entire bevel. However, it's really not the blade, it's the knots. Knots don't play well with hand tools. Stick to clear boards and you won't have any problems. I use old hand planes bedded at 45-55 degrees with a 25-30 degree bevel angle on end grain all the time and it's no problem. If you absolutely have to plane the knots, you need a freshly sharpened blade and you need to take a very fine cut. But I would suggest just avoiding boards with knots. They're typically not worth the effort and agrivation.
Thanks for your wisdom Bob. It sounds like the knots are the explanation. I had never encountered this before but I hadn't used any knotted timber in any of my previous projects. These were just some scrap roofing timber with knots that I had laying around that I was testing the plane on.
