Grain Filler with Vinyl Primer and Precat Lacquer
Hello!
My husband and I are refinishing some vintage dressers and we want them to have a smooth high gloss finish. The dresser we are currently working on has deep grain and we aren't sure of the best way to fill it. We are using Sherwin-Williams Vinyl Primer Surfacer and High gloss white Hi-Bild Precat Lacquer, spraying with an HVLP gun.  What is the best way to fill the grain?
Thanks,
Kirsten J.
You can use a wood grain filler. Or you can fill it with your products.
What type of wood is this and can you post a picture of your project please?
I'm not sure of the wood type. Here is a picture of the drawer fronts > http://www.flickr.com/photos/kelizabeth511/8686176333/ Everything has already been sanded down to the bare wood. Could I do two double pass coats of the vinyl primer, sand, and then go on with my lacquer? Would that be enough to fill the pores? I'm worried about building too much with the precat lacquer because the spec sheet has a recommended thickness of 3.0-5.0 mils wet and I've read I can run into problems like cracking if I use too much product.
Thanks!
Looks like ash to me or even oak. Now I don't prime too much of my stuff but I'd usually do several coats and then top it off. However I don't think you'll file the grain in two coats.
You are right about the mills wet. However, this is for a wet coat. After it has dried (and even cured?) it'll shrink (normal). Lacquer will dissolve into the previous coat to preform one coat. Now if you apply it too thick it'll drip and sag and that's just before it dries. You'll experience cracks and other headaches. Put that'll extremely thick. Something ridiculous like 15 mills wet.
Now I think you'll finishing Schedule should be as follows:
4 coats primer
4 coats white lacquer.
Enjoy.
I'd like to top of opaque lacuqer with a clear coat of lacquer but this is just personal preference. As long as your lacuqer is fine, your spray guns are setup properly, your workarea is clean and of sufficient humidity you will not have a single problem.
Thanks so much for your help!
I've primed 4 times and the grain is almost completely filled. Would I be safe moving on to the lacquer? Would it fill the remainder?
Absolutley. If you feel that the lacquer won't feel it up you can continue with the primer or more lacquer.I hope you are sanding between coat though.
Be sure to post a picture of the finished piece afterwards.
Thanks!
Your not going to get that smooth without grain filler. Your vinyl sealer is the moisture barrier. Most precat lacquers by themselves don't meet cabinetry standards. Yes you are correct it 3-5 mils dry max or you may have cracking issues. To determine dry mils use solids content. Multiply solids by wet mils.
Keep on rocking with what your doing. The key to grain filing is sanding back level your finish then adding more coats till you fill the grain. The finish will build on the edges of the grain pockets. Think of it as a mountain top and your grain pocket is the valley. You need to knock off the mountain tops till the valley fills up with finish.
So by sanding back between coats, your dry mill thickness shouldn't be a worry.
Hope this helps.
-Ace-
