rbterhune Posted September 28, 2010 Report Share Posted September 28, 2010 Hello...I am new to these forums and new to woodworking. At some point, when funds are available, I will embark on my first project...a nightstand with frame and panel sides. The top and bottom rails are 5+" wide and here is my question. How much of the stub tenon should I glue to the stiles and if not 100% of the width, how much and where? Of course, my panel will not be glued...it will be 1/4" solid cherry. Thanks, Brad Quote Link to comment Share on other sites More sharing options...
Bobby Slack Posted September 28, 2010 Report Share Posted September 28, 2010 Here is a video from Popular Woodworking. A video is worth one million words. http://www.popularwoodworking.com/article/video_where_does_the_glue_go/ Fine Woodworking has a ton of stuff if you subscribe online. Good luck. Quote Link to comment Share on other sites More sharing options...
dryhter Posted September 28, 2010 Report Share Posted September 28, 2010 Hello...I am new to these forums and new to woodworking. At some point, when funds are available, I will embark on my first project...a nightstand with frame and panel sides. The top and bottom rails are 5+" wide and here is my question. How much of the stub tenon should I glue to the stiles and if not 100% of the width, how much and where? Of course, my panel will not be glued...it will be 1/4" solid cherry. Thanks, Brad Welcome Brad, 5 in. sounds pretty beefy for a night stand. How big are the stiles? Are you using true tenons or a cope and stick. I have glued up cope and stick panels that big and bigger without a problem. but if you are going a more traditional route you may want to go with about a 4in. tenon, but make it a haunched tenon and just glue up the big part. or just leave it loose and put a peg or two in it. Good luck with the project Dave Quote Link to comment Share on other sites More sharing options...
rbterhune Posted September 28, 2010 Author Report Share Posted September 28, 2010 Well, the stiles are 3". Yes, it seems beefy, but it makes sense for the Stickley design. I had not planned on using a "traditional" tenon at all...only the stub tenon fitted to the groove...more of a cope and stick. What do you think of that? Welcome Brad, 5 in. sounds pretty beefy for a night stand. How big are the stiles? Are you using true tenons or a cope and stick. I have glued up cope and stick panels that big and bigger without a problem. but if you are going a more traditional route you may want to go with about a 4in. tenon, but make it a haunched tenon and just glue up the big part. or just leave it loose and put a peg or two in it. Good luck with the project Dave Quote Link to comment Share on other sites More sharing options...
dryhter Posted September 29, 2010 Report Share Posted September 29, 2010 Hey Brad, I think you will be fine as long as the joints are not structural or under load or stress. It's better then just buttin two boards together. If you had a biscuit joiner this would be the time to use it . How do you plan on cutting the grooves and tenons? Dave Quote Link to comment Share on other sites More sharing options...
rbterhune Posted September 30, 2010 Author Report Share Posted September 30, 2010 I'm going with a router for both I believe. Quote Link to comment Share on other sites More sharing options...
