I, like most people, run a wireless network in my home. I connect my iPad, my laptop, and my wife's laptop to it all the time without issue. I use a modern n class wireless router.
I just got two new cell phones (both motorolla moto g) and I am having issues on wifi with them. I can connect them and they work great, but only when I go to my wireless router and hit the WPS button. They work on wifi when I do this, as long as I don't leave the wifi area.
It's a PITA to go and hit this button everytime I leave the house with my phone and return.
Is there a way to "make it stick" so I don't have authentication problems everytime I come home?
If the connection keeps dropping, go to Settings > Wi-Fi > Advanced and consider changing two settings. Make sure Keep Wi-Fi on during sleep is set to Always. Make sure Avoid poor connections is not ticked.
Thanks for the tips. I tried, but no better.
This is not easy but, it help a few people from a forum.....
"On my Moto G I couldn't connect to Wifi at all on my home system. I went to the Motorola web site and on their forum they have a chat. I started a chat and they gave me a procedure to Clear the Cache Partition. This doesn't affect any of your software, or any changes of any kind that you have made. After using this procedure of which it does say that you should see a screen come up, of which I never did see it and I tried it 3 times. But when I booted up and went into to Wifi mine was connected and stayed connected. I then powered the phone down and backup and went it Wifi again and it was still connected. I have had a solid connected for over an hour now and before I could not connect at all except using WPS. I'm now very happy with Wifi and I have Xfinity at 30 meg so on the Moto G, and it's fast. I checked my software and other things that I added and I could not find a problem. You may want to give this a try.
To Resolve Wifi Connection Problem
How do I clear Cache Partition on my device?
This will remove any temporary files that may be causing the problem, but will not delete your files or settings.
1. With the phone powered off, press the VOL DOWN KEY for 2-3 seconds then POWER key then release.
2. The device will display different BOOT OPTIONS
3. Use the VOL DOWN Key to SCROLL to Recovery and VOL UP Key to select
Tip: If the device reboots, you may have waited to long to make a selection, you will need to begin the process again.
4. The device will display the Motorola logo and then the Android in distress ( logo with Exclamation mark)
5. Press and hold the VOL UP key for 10-15 seconds. While still holding the VOL UP key tap and release the POWER key
Tip: You can try this step, holding the phone in landscape. If you are stuck on step 6, try a force reboot by pressing the Power key and Vol Down key, and start the process again.
6. The device will display additional menu options (Text will appear in BLUE)
7. Use the VOL DOWN Key to scroll to wipe cache partition and the POWER Key to select this option
8. The device will then perform the partition wipe
9. The device will reboot and start the normal power up sequence
  • Who's Online   1 Member, 0 Anonymous, 41 Guests (See full list)
    32k
    437.5k
    26,007
    FurniCore
    FurniCore
