Need help with a chair
Hi there new to the site and to wood working.  I need some advice on this chair's top back support.  First you can see its not square, the bottom of the right mortise is about a 1/4" higher than the other so if I bottom the support or top it I will have a gap on one side or the other.  If I center it there's a bit of a gap on each.  Also, there's a gap between the face of the support and the chair leg that I cant clamp out.  It will butt up flat when its attached to one leg only, when I attach the other leg, I cant pull the legs in enough to close the gaps.  I think the center and lower supports just dont have the extra play.  I was thinking about cutting back the supports a little but the tenons were hand cut and arent much thinner than the supports themselves, about 1/8" on the front and 1/16" or less on the back (hope that makes sense).  Any ideas sure would be appreciated.  This is my first project, the chair is an antique not sure how old it is, the nails I pulled out of it looked like railroad spikes.  I think the wood is maple but not sure any ideas on that?
post-15554-0-02050200-1400863467_thumb.jpost-15554-0-70976500-1400863469_thumb.j
Hi welcome to the forum. I would be inclined just to leave it be and centre it the best you can before regluing. Not sure what species it is as identification is not so easy from the pictures you have.
Thanks for the input, here's a bad picture of the seat Im not sure if this would be any help in identifying.  Im guessing its maple.  I have a another cane seat chair but its a rocker.  Its seat is constructed the same with four pieces, was this common to a certain era or style?  This chair was originally stained then painted.  Im not sure if the rocker was stained first as well.
post-15554-0-60319500-1401253360_thumb.j
I have seen plenty of old and new chairs with slightly to greatly mis-aligned parts. Just get it as close as you can without any major recutting, glue it up and maybe clean up the exposed rough or sharp corners. It looks like a chair that can be functional and maybe has some sentimental value, but I don't perceive it as an extraordinary piece worthy of extended efforts.
Steve thanks for the advice, this is my first project I really bought it to practice caning the seat.  I have a similarly constructed rocker that I can wait to get started on.
  • 26,009 Total Members
  • Joseph b Newest Member ·
