Fast Drying Oil Polyurethane Crack / Crackled
Refinishing the top of an antique mahogany vanity simultaneously with a maple kitchen/dining table with 4 leaves. I've not had any problems with the vanity. All was going well until this last coat.  In areas on the table it has now crackled & 2 star shaped wrinkles.  I'm very familiar with crackling paint & understand the process.  I'm trying to figure out what circumstances could create polyurethane to do so that are not in my knowledge arsenal plus advice on what to do without re stripping & starting from scratch.
I'm spraying with HVLP in my booth in the garage with filtered ventilation/airflow (I know there's lots of opinions against this)
Temperature was in the 70's at that time of the day with low humidity around mid to low 30%
This was the 4th coat of MW Fastdrying Oil Based thinned 3:1 or 75% poly 25% mineral spirits
The fist 2 coats were applied 1 week before
While spraying my circuit breaker safety installed between the compressor & outlet tripped. I do think that kept the gun from atomizing right & allowed it to go on a little thicker than all the rest. When I very first used poly I would brush it on too thick & never had it do this. I've scoured the www & can't find anything on this.
I'm so very frustrated.
post-15642-0-52092300-1401291014_thumb.j
post-15642-0-11214200-1401291016_thumb.j
post-15642-0-63481100-1401291017_thumb.j
post-15642-0-22240900-1401291019_thumb.j
post-15642-0-78764500-1401291020_thumb.j
How long between 3rd and 4th coats? It looks like too thick of a coat to me. If the 3rd coat hadn't hardened and cured then a thick coat over it would just add to the situation.
Any chance you had the pieces sitting in the sun for a while prior to coating?  This is something that can happen when the solvents in the finish 'flash' off too quickly allowing the skin to form before the finish has a chance to flow out and get happy.  Rapid flashing can happen 1 of two ways (or a combination of the two).  Too much air flow, or the surface is too warm on application.
Thank you all so much for replying!!
That last coat was applied 3 hours after the one before.  I sprayed inside a booth inside my garage.  The temps were in the 70's.  I do have a fan at each end, one for intake one for exhaust.  It is not a crazy strong current though.  I suspect that last coat on the table was too thick with the compressor not running.  I will sand down today if it is dry enough & apply one last super thin coat, might even do a 1:1 wipe on since I'll have to sand & there's enough of a build on it now. Fingers crossed that it sands out decently!!
  • 26,009 Total Members
  • Joseph b Newest Member ·
