Light placement for spraying clearcoat
I have one of the mid-range hvlp sprayers that I use for clearcoat. I just spray in my shop or outside (depending on weather). One of my biggest challenges is getting the lighting set up so that I can make sure I can see the edge of each pass to make sure I overlap properly etc.. I have a variety of portable halogen work lamps, but it seems that no matter what I do there is always some point in the application where I can't see the last pass and I am basically spraying blind.
My shop is in a dbl garage, so the door on the end opens and I can get natural daylight coming in one end if I want to (also helps with ventilation). The main shop lighting is a grid of compact flourescents spaced 4' in each direction.
For small things I can move or turn them a bit as needed - but for large doors and stuff this isn't possible.
It does seem that I can see better when the light reflects off the wet coating at an angle.
Oh - it is not so much of a problem with paints or colored topcoats - or even the first pass when the wood is dry ... but on pass #3 of clear it can be a problem.
What do you do (if you spray clearcoat)?
That's basically the trick. Roughly 45 degree angle of the light to the work surface. Big help is to have multiple lights for the different angles as you progress around the work piece :-)
I got some of those architect lamps at IKEA and bright LED flood lamp bulbs from Costco. The LED bulbs weigh more than other bulbs so I did have to get some stronger springs for the swing arms. I have them all around the shop so I can adjust the light and direction when I am finishing.
The compact Flourescent flood lights work but not as well and take time to achieve full brightness . They also do not last as long.
  • 26,009 Total Members
  • Joseph b Newest Member ·
