JohnnyNoName Posted April 17, 2011 Report Share Posted April 17, 2011 I am probably in the minority with this, but I use Adobe Illustrator for almost all of my initial design drawings. Illustrator doesn't have a fractions settings, so I need to convert back and forth from decimals to fractions for my measurements. Today I found this convenient little chart online that has all of the fraction to decimal conversions by sixty-forths of an inch. I thought maybe someone would find it useful. Fraction to decimal conversion chart Jonathan ===================================== Quote Link to comment Share on other sites More sharing options...
ChetlovesMer Posted April 17, 2011 Report Share Posted April 17, 2011 Okay, I'm curious what you like about adobe? I've pretty much only used sketch-up... oh and/or paper and pencils. Quote Link to comment Share on other sites More sharing options...
JohnnyNoName Posted April 17, 2011 Author Report Share Posted April 17, 2011 Okay, I'm curious what you like about adobe? I've pretty much only used sketch-up... oh and/or paper and pencils. Chet - I use Illustrator, because it's what I'm use to. I've been a graphic/web designer for 15 years, and I have used Illustrator for that long. Some things that I like about using Illustrator are: - I can create plans very quickly - Scaling is very easy - I think setting up proportions is easy - Exact dimensions are easy - The drawing tools are very easy to use (That is what it was created for after all :-) My usual design process is to draw/sketch on paper. Then when I get a basic idea of what I want to do, I create the elevations/plans in Illustrator. If everything seems a go, I will then create a model in Sketch-Up. I like sketch-up, but I find it takes much more time to create a basic idea, when compared to Illustrator. It could be that I am just a lot faster in Illustrator, and I haven't used Sketch-Up enough. I don't know. Now just to be clear, I am talking about Adobe Illustrator, and not Adobe Photoshop - two entirely different applications. Jonathan ================================= Quote Link to comment Share on other sites More sharing options...
